Where are the servo examples/lib in 1.05 R2?... knob and sweep?
I loaded the knob example to an Uno in ERW 1.05 and then I had my boot disk crash later.. I installed 1.05 r2 and I can't find the example or the library anywhere except in the old saved images that I moved to another drive...
Doc
I just downloaded the .zip-version to see for myself... Servo library is present!
You are right... I posed the question after looking in the examples where I couldn't find it although it shows in the previous releases...
I can only assume that I have too many examples and as such I guess... That I will have to open the 1.05 r2 examples folder and select the required 'example' manually and have it start the IDE... Seems really B'wards to me... I wonder why all the drop down menu's aren't scrollable as the release notes for 1.05 r2 state:
- Example and Boards are now scrollable.
I wonder what the emphasized text refers to as servo should come before streaming and all that does is rotary... then streaming... So I asked.
I do apologize for a really dumb question and for wasting time on something I should have done myself...
Funny, though it did/does in ERW 1.04 & 5. I would have re installed 1.05 but I couldn't find it on my system...
I do however have a large drive farm.. 3 TB in the box and 2 TB external.... Drives are cheap lately...
I guess I got bit by my greed..
[Edit.. I read the release notes before really deciding on which version to install and based on that one line chose to use 1.05 r2
Doc
