Does anybody have working library files for Servo2 and code which works with it.
MY library states I have contributed “ServoTimer2” and not “Servo2”… are they the same ???
I am getting very confused trying to get the simple Servo Knob code to work, using Servo2 library…
Controlling a servo position using Timer 2 and a potentiometer (variable resistor)
by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
//#include <Servo.h> // imports servo library
//#include <Servo2.h> // ???? doesnt work - maybe one below - imports servo library
#include <ServoTimer2.h> // ???? doesnt work - imports servo library
ServoTimer2 myServo; // associated myservo object will all resources in servo library
int const potpin = A0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin measured at A0
int angle; // variable to read the servo angle value
myServo.attach(6); // attaches the servo on pin 6 (was 9) to the servo object
Serial.begin(9600); // setup serial comms to read angle and volts
val = analogRead(potpin); // reads the value of the pot. and converts to digital value (value between 0 and 1023)
Serial.print("Val:"); // serial print the text "Val:"
Serial.print(val); // serial print new line variable in Val
angle = map(val, 0, 1023, 0, 180); // does scaling for us (val - # to be scaled; 2nd/3rd - min/max ad conv; 4/5th - min/max servo)
Serial.print(",Angle:"); // serial print the text "Angle:"
Serial.println(angle); // serial print new line variable in Angle
myServo.write(angle); // sets the servo position according to the scaled value
delay(85); // waits for the servo to get there
It wont compile as I don’t believe it can see the Servo2 library.
… and reports;
In file included from sketch_ServoTimer2_jun28a.ino:11:0:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:117:14: error: conflicting declaration ‘typedef bool boolean’
typedef bool boolean;
In file included from sketch_ServoTimer2_jun28a.ino:9:0:
C:\Users\andy.upton\Documents\Arduino\libraries\ServoTimer2/ServoTimer2.h:59:17: error: ‘boolean’ has a previous declaration as ‘typedef uint8_t boolean’
typedef uint8_t boolean;
Error compiling.
