Hello! In an attempt to create my own servo ISR that manually sets pins high and low rather than depending on the timer, I decided to go through the existing servoISR code to see how it's done. I am confused by a line that claims to be clearing a flag:
Servo.cpp
Line 59-60
/* clear the interrupt (by writing 0 to IP bit of the control register) */
aux_reg_write(ARC_V2_TMR1_CONTROL, ARC_V2_TMR_CTRL_NH | ARC_V2_TMR_CTRL_IE);
Line 113-114
/* count only when not halted for debug and enable interrupts */
Here are some definitions:
aux_regs.h
#define ARC_V2_TMR1_CONTROL 0x101
conf.h
#define ARC_V2_TMR_CTRL_IE 0x1 /* interrupt enable */
#define ARC_V2_TMR_CTRL_NH 0x2 /* count only while not halted */
#define ARC_V2_TMR_CTRL_W 0x4 /* watchdog mode enable */
#define ARC_V2_TMR_CTRL_IP 0x8 /* interrupt pending flag */
#define aux_reg_write(reg, val) __builtin_arc_sr((unsigned int)val, reg)
Can anyone explain what line 60 in Servo.cpp is really doing?
It seems like this is happening:
ARC_V2_TMR_CTRL_NH | ARC_V2_TMR_CTRL_IE = 10 | 1 = 11
so we would be writing the value '3' to register ARC_V2_TMR1_CONTROL.
Shouldn't it be something like:
aux_reg_write(ARC_V2_TMR1_CONTROL, (0 << ARC_V2_TMR_CTRL_IP))
Another thing to note is that rather than actually clearing that interrupt pending flag, we are actually just calling timer1_init_servo every time we want to set a new limit and reconnecting the ISR to the timer. Is this correct or a best known method?
Thanks!
