Servomotor and 2 Stepper motors programme
Hello!
I've been trying for weeks to make work 2 stepper motors and 1 servomotor with an arduino UNO board and an adafruit motor Shield, because I have to do an school project with them. I've tried so many different programmes but I only can make work the servo. I've connected the steppers in motor pins (one in M1 and M2 and the other one in M3 and M4).
I can't find the problem, but I suppose that the programme I'm using is not the correct one. Can anybody give me a programme which can make work these three components at the same time? I don't mind the speed or the sequence, I can modify it if I need it, but I only want to make it work together.
The motors I'm using are these: Stepper motor - NEMA-17 size - 200 steps/rev, 12V 350mA : ID 324 : $14.00 : Adafruit Industries, Unique & fun DIY electronics and kits and the shield is this one: Motor/Stepper/Servo Shield (Version 2) | Adafruit Shield Compatibility Guide | Adafruit Learning System
Thank you very much and sorry for my English.
So post one. Along with a schematic showing how you have wired it up and information about the power supply you are using for the motors.
That stepper motor, as its info page mentions will need 2 full H-bridges to power it,
you need to use one H-bridge for one winding (red/yellow) and the other for the other
(green/brown-grey)
You don't say exactly which motor shield alas - there are two at least from Adafruit,
and they are very different.
Grumpy_Mike:
I've used this to move only one stepper (it doesn't work too):
#include <AFMotor.h>
AF_Stepper motor(200, 2);
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Stepper test!");
  motor.setSpeed(50);  // 10 rpm
  motor.step(100, FORWARD, SINGLE);
  motor.release();
  motor.step(100, BACKWARD, SINGLE);
  motor.step(100, FORWARD, DOUBLE);
  motor.step(100, BACKWARD, DOUBLE);
  motor.step(100, FORWARD, INTERLEAVE);
  motor.step(100, BACKWARD, INTERLEAVE);
  motor.step(100, FORWARD, MICROSTEP);
  motor.step(100, BACKWARD, MICROSTEP);
And this to move one stepper and the servomotor (it only make work the servo):
#include <Servo.h>
// DC motor on M2
AF_DCMotor motor(2);
// DC hobby servo
Servo servo1;
// Stepper motor on M3+M4 48 steps per revolution
AF_Stepper stepper(200, 2);
  Serial.println("Motor party!");
  // turn on servo
  servo1.attach(10);
  // turn on motor #2
  motor.setSpeed(200);
  motor.run(RELEASE);
int i;
// Test the DC motor, stepper and servo ALL AT ONCE!
  motor.run(FORWARD);
  for (i=0; i<255; i++) {
    servo1.write(i);
    motor.setSpeed(i);
    stepper.step(1, FORWARD, INTERLEAVE);
    delay(3);
  for (i=255; i!=0; i--) {
    servo1.write(i-255);
    motor.setSpeed(i);
    stepper.step(1, BACKWARD, INTERLEAVE);
    delay(3);
  motor.run(BACKWARD);
    servo1.write(i);
    motor.setSpeed(i);
    delay(3);
    stepper.step(1, FORWARD, DOUBLE);
    motor.setSpeed(i);
    stepper.step(1, BACKWARD, DOUBLE);
    delay(3);
I'm connecting them like the foto shows
Thanks
MarkT:
(green/brown-grey)
I don't know how to use H-bridges :~
I'm using this connections, is it anything wrong?
Thanks
As Mark says:-
Can you provide a link to the motor shield you are using.
Also can you provide a link to that stepping motor library you are using.
The shield is the one which appears in the foto here Motor/Stepper/Servo Shield (Version 2) | Adafruit Shield Compatibility Guide | Adafruit Learning System
And the library is this https://github.com/adafruit/Adafruit-Motor-Shield-library/zipball/master
Clearly the wrong library - you have version 2 of the motor shield, if you follow the
tutorial pages (which you should have done from the start) it very clearly points you
to this library:
MarkT:
to this library:
Install Software | Adafruit Motor Shield V2 | Adafruit Learning System
It works perfectly, I was going crazy!
Karma for you, thanks a lot!!! :slight_smile:
