Hi !
First of all, sorry if I'm not in the good category, I'm new here ![]()
I want to make a system that compensates for tremors suffered by a spoon.
So I have an mpu (mpu1) which is used to calculate the angle at which I lean my board and a servomotor which returns the opposite angle so that the spoon at the end of the servo remains straight (see image).
I have a second mpu (mpu2) which allows me to calculate the angle at the end of the spoon (which must therefore be smaller than that of mpu1), so that I can create a chart with the entry angle and the exit angle
Here is the code I made:
// ######## Declaration of Libraries ########
#include <Wire.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Servo.h>
// ######## Variable initialization ########
Adafruit_MPU6050 mpu1;
Adafruit_MPU6050 mpu2;
Servo servo;
float angx1, angy1, angz1;
float angx2, angy2, angz2;
float acc_total_vector1, acc_total_vector2;
int val;
int preVal;
int temps;
// ######## Program initialization ########
servo.attach(6);
Serial.println(F("Initialize System"));
if (!mpu1.begin(0x68) && !mpu2.begin(0x69)) {
Serial.println("Failed to find MPU6050 chip");
mpu1.setAccelerometerRange(MPU6050_RANGE_16_G);
mpu2.setAccelerometerRange(MPU6050_RANGE_16_G);
mpu1.setGyroRange(MPU6050_RANGE_250_DEG);
mpu2.setGyroRange(MPU6050_RANGE_250_DEG);
mpu1.setFilterBandwidth(MPU6050_BAND_21_HZ);
mpu2.setFilterBandwidth(MPU6050_BAND_21_HZ);
// ######## Reading data ########
sensors_event_t a1, g1, temp1;
mpu1.getEvent(&a1, &g1, &temp1);
// Calculation of the total 3D acceleration vector : √(X² + Y² + Z²)
acc_total_vector1 = sqrt(pow(a1.acceleration.x, 2) + pow(a1.acceleration.y, 2) + pow(a1.acceleration.z, 2));
// To verify that the value is within [-1;+1]
if (abs(a1.acceleration.x) < acc_total_vector1) {
angx1 = asin((float)a1.acceleration.y / acc_total_vector1) * (180 / PI);
if (abs(a1.acceleration.y) < acc_total_vector1) {
angy1 = asin((float)a1.acceleration.x / acc_total_vector1) * (180 / PI);
sensors_event_t a2, g2, temp2;
mpu2.getEvent(&a2, &g2, &temp2);
acc_total_vector2 = sqrt(pow(a2.acceleration.x, 2) + pow(a2.acceleration.y, 2) + pow(a2.acceleration.z, 2));
if (abs(a2.acceleration.x) < acc_total_vector2) {
angx2 = asin((float)a2.acceleration.y / acc_total_vector2) * (180 / PI);
if (abs(a2.acceleration.y) < acc_total_vector2) {
angy2 = asin((float)a2.acceleration.x / acc_total_vector2) * (180 / PI);
// ######## Data for the servo motor ########
val = angx1;
if (val != preVal) {
servo.write(val);
preVal = val;
// ######## Show values ########
Serial.print(millis());
Serial.print("/");
Serial.print(angx1);
Serial.print("/");
Serial.println(angx2);
delay(1);
I am having several problems:
- angx1 varies on [-90;+90] but the servo only varies on [0;+90]
- the engine does not respond fast enough to use it on tremors (I tested with delay(1) and delay(0), and it's the same); I can only use it on slow movements
- when i show angx1 and angx2 values in serial monitor, angx2 is equal to angx1
Can someone please help me?
Thanks in advance !
