I have a WiFi controlled robot. Originally I used an Arduino Mega with a WiFi shield. I have replaced that with the Yun.
For the Mega I used UDP to communicate and it was working fine. For the Yun I have changed over to TCP. I use the Yunserver and Yunclient. I'm using the standard Arduino servo library.
I have enabled a debug mode to write values to the console to make sure it's not an issue with communications. The values are coming over as expected. My TCP packets send values from 0 to 180 for the servos. when sending a value of 0, the servo should go all the way one direction. When sending 180 it should go all the way the other direction.
Standard servos expect pulses from 1 ms to 2 ms wide every 20 ms. I'm guessing that the interrupts for the incoming packets are interrupting the timing and the pulses are not at the correct timing.
If I run the servo sweep example, the servos react fine. Its only when I enabled networking that they get messed up.
I have moved the servos around to different I/O pins and I get the same results.
Have anyone else seen this? Does anyone have any ideas for how to resolve this?
