Servos and flex sensors
Hi MarkT can you help me regarding Servo (SG90) and Flex Sensors(2.2 inch) with Arduino. I have from many sites but nothing been corrected.
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to const int analogOutPin = 9; // Analog output pin that the LED is attached to
int sensorValue = 0; // value read from the pot int outputValue = 0; // value output to the PWM (analog out)
void setup() { // initialize serial communications at 9600 bps: Serial.begin(9600); }
void loop() { // read the analog in value: sensorValue = analogRead(analogInPin); // map it to the range of the analog out: outputValue = map(sensorValue, 0, 1023, 0, 179); // change the analog out value: analogWrite(analogOutPin, outputValue);
// print the results to the serial monitor: Serial.print("sensor = " ); Serial.print(sensorValue); Serial.print("\t output = "); Serial.println(outputValue);
// wait 2 milliseconds before the next loop // for the analog-to-digital converter to settle // after the last reading: delay(2); }
This is Arduino own example Analog in and out. Can you help me
Hney: Can you help me
What's your actual question? You mention servos and flex sensors, but post code about potentiometers and leds.
