Hi all,
I'm trying to control multiple servo's and multiple dc motors, for which I use PWM via a motor driver. However, the Servo's are also responding if I change the values for the PWM of the motors. I already read a lot of people who had the same problem, but is there a workaround? Or is PWM completely unusable when you want to use Servo's? I am already using pin 9 and 10 and 6 for the servo's and pin 3 and 5 and 11 for the dc motors.
Thank you very much for your help!!
This is my code:
// This program is used to control the blimp made by Blimp Monkeys.
int ledPin = 13; //declare variable ledPin. 13 is the address of the port
//to which the LED is connected.
#include <Servo.h> // standard servo library
const int lM0 = 0, lM1 = 1, lM2 = 2, lG0 = 3, lG1 = 4, lG2 = 5, lS1 = 6;
Servo G1; // declare servo objects
Servo G2;
Servo S1;
int G1P = 7;
int G2P = 10;
int S1P = 6;
int M0P1 = 2;
int M0P2 = 4;
int M0PP = 3;
int M1P1 = 9;
int M1P2 = 8;
int M1PP = 5;
int M2P1 = 12;
int M2P2 = 13;
int M2PP = 11;
void WaitAndBlink( unsigned long DeltaMilliSec){
// wait DeltaMilliSec milliseconds, LED blinks as a sign of life
// as time passes frequency increases
unsigned long DeltaT = 0;
unsigned long TZero = millis(); //read start time
while(DeltaT<DeltaMilliSec){
unsigned long TCurrent = millis();
DeltaT = TCurrent-TZero; //compute elapsed time
delay(500-400*DeltaT/DeltaMilliSec);
digitalWrite(ledPin,LOW);
digitalWrite(ledPin,HIGH);
SoftPWMBegin();
pinMode(13,OUTPUT);
Serial1.begin(115200); // Read from wifi
G1.attach(G1P);// Attach to servos
G2.attach(G2P);
S1.attach(S1P);
G1.write(180); // Set servo to default position.
G2.write(50);
S1.write(30);
// Set all motor outputs to 0
pinMode(M0P1, OUTPUT);
pinMode(M0P2, OUTPUT);
// pinMode(M0PP, OUTPUT);
pinMode(M1P1, OUTPUT);
pinMode(M1P2, OUTPUT);
//pinMode(M1PP, OUTPUT);
pinMode(M2P1, OUTPUT);
pinMode(M2P2, OUTPUT);
//pinMode(M2PP, OUTPUT);
//Wait for things to get ready
WaitAndBlink(10000);
// read the input buffer until it is empty
// any character in the buffer is ignored
while (Serial.available()){
Serial1.read();
if(Serial1.available()){
char in = Serial1.read();
delay(1);
int val = Serial1.read();
bool neg = 1; //val < 0;
switch(in){
case '0' :
/*if(neg){
digitalWrite(M0P1, 1);
digitalWrite(M0P2, 0);
}else{
digitalWrite(M0P1, 0);
digitalWrite(M0P2, 1);
digitalWrite(M0P1, HIGH);
digitalWrite(M0P2, LOW);
analogWrite(M0PP, val);
delay(10);
case '1' :
if(neg){
digitalWrite(M1P1, 1);
digitalWrite(M1P2, 0);
}else{
digitalWrite(M1P1, 0);
digitalWrite(M1P2, 1);
analogWrite(M1PP, val);
case '2':
if(neg){
digitalWrite(M2P1, 1);
digitalWrite(M2P2, 0);
}else{
digitalWrite(M2P1, 0);
digitalWrite(M2P2, 1);
analogWrite(M2PP, val);
case 'g':
G1.write(val);
case 'h' :
G2.write(val);
case 's' :
S1.write(val);
if(val < 100){
digitalWrite(ledPin, LOW);
}else{
digitalWrite(ledPin, HIGH);
}else{
//S1.write(0);
delay(1);
