hi guys,
i'm a complete new bee, i've buy an arduino uno to control one servo, i need to control it with a very simple program to move it in the 0° position to the 180°position, wait here for 25seconds, and go back to the 0 position, waiting 25sec and again and again...
does this little program will do this:
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 10) // goes from 0 degrees to 180 degrees
{ // in steps of 10 degrees
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(20000); // waits 20sec for the servo to reach the position
for(pos = 180; pos>=1; pos-=10) // goes from 180 degrees to 0 degrees
Your opinion and help will be appreciated.
best regards
christophe
yes , but it's just for example, in fact i'll change this delay with test, the most important it's to have the delay in seconds, and to change it, if needed.
do you think this code like writting here will do this? (with the 20sec delay).
myy arduino it's on the way and i'll try the code as soon as receive.
your opinion will be appreciated.
may be if someone have one arduino linked with an servos , someone can test this.
christophe
#include <Servo.h>
int a = 10;
int b = 170;
myservo.write(a); //set initial servo position if desired
myservo.attach(7); //the pin for the servo control
Serial.println("servo-test"); // so I can keep track of what is loaded
myservo.write(a);
Serial.println(a);
delay(5000);
myservo.write(b);
Serial.println(b);
delay(5000);
zoomkat:
Is something like below what you are looking for?
#include <Servo.h>
int a = 10;
int b = 170;
oh , in this case it's only the loop who have delay, is it correct?
in mine i've put the delay in the travel of the arms position.
if it's that , i understand, and will try this one, and make you one video to show youthe result as soon as i receive the arduino.
thanks for all your help.
regards
christophe
If I understand correct you nedd a loop() like this:
for(pos = 0; pos <= 180; pos += 10) // goes from 0 degrees to 180 degrees
delay(15); //delay so that servo reach new position - depends on step - experiment with speed;
delay(25000); //waits 25sec in 180 deg. position
for(pos = 180; pos>=0; pos-=10) // goes from 180 degrees to 0 degrees
christophe31:
So you want:
#include <Servo.h>
Servo myservo;
myservo.write(0); // Set initial position
myservo.write(180); // "move it [from] the 0° position to the 180°position,"
delay(25*1000); // "wait here for 25 seconds,"
myservo.write(0); // "and go back to the 0 position, "
delay(25*1000); // "waiting 25 sec"
// "and again and again..."
hi guy's,
i've receive tonight my arduino uno, and after 5 min of coding, try the code that you have give to me, and i've found one who work fine like i want :
goes to one position
Wait the time i want there
goes to the original position.
here the code: #include <Servo.h>
for(pos = 0; pos < 180; pos += 180) // goes from 0 degrees to 180 degrees
{ // in steps of 180°
delay(28000); // waits 28s for the servo to reach the position
for(pos = 180; pos>=1; pos-=180) // goes from 180 degrees to 0 degrees
{ // in step on 180°
Well, that's one(long winded) way of doing it.
Simpler might be
ok so i've try this simplest code, but now, the servos don't do the loop, in fact it does the code one time , and that's all......
any idea?
how to proceed to be sure to erase and empty the memory ? to upload code like new card
edit:
i've succeed with this code: #include <Servo.h>
Servo myservo;
Servo servo_b; // create servo object to control a servo
myservo.attach(9);
servo_b.attach(10); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos<=180; pos += 180) // goes from 0 degrees to 180 degrees
delay(22000); // waits 28s for the servo to reach the position
for(pos = 180; pos>=1; pos-= 180) // goes from 180 degrees to 180 degrees
delay(100); // waits 28s for the servo to reach the position
don't take care of the servo_b, it'ss for another function, and as you note the second delay ( 100ms), doesn't do anything, the servos goes in up/down position each 22sec,
christophe
any idea?
Sounds like you put that code in the setup() function instead of the loop() function. If it was in the loop() function, it would get executed repeatedly. It's very simple code, so there's really no room for any other explanation.
Is it planned that this should take a total of 3960 seconds (66 minutes) to complete this loop?
And you really should update your comments to actually tell what it is doing, it can be very confusing when the code says one thing, and the comment says something else.
Another way of doing it, and make the servo move slower, and complete the distance in 21.96 seconds, could be like doing it like this
#include <Servo.h>
for(int pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
delay(122); // waits 122ms for the servo to reach the position
for(int pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
Not even sure whey it needs to wait 22 seconds to get to position... it should take less than 1 second to move from one side to another...
