I'm doing a project in which i need to rotate servos at same time but with my code they rotate one after the other i would be thankful if you guys helped me here's the code:
//Добавя се библиотеката на серво моторите
//Даваме индентифиционен номер/име на серво моторите
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
int val;
//Позиция на сервотата в градуси
int down = 0;
int up = 90;
Serial.begin(9600); // Serial comm begin at 9600bps
//Казваме къде са включени сервотата (3-5-6-9-10-11)
servo1.attach (3);
servo2.attach (5);
servo3.attach (6);
servo4.attach (9);
servo5.attach (10);
servo6.attach (11);
servo1.write(down);
servo2.write(down);
servo3.write(down);
servo4.write(down);
servo5.write(down);
servo6.write(down);
if (Serial.available()) // if serial value is available
val = Serial.read();// then read the serial value
if(val == 'a' or val== 'b' or val == 'c' or val == 'd' or val == 'e' or val == 'f' or val == 'g' or val == 'h' or val == 'k' or val == 'l' or val == 'm' or val == 'n' or val == 'o' or val == 'p' or val == 'q' or val == 'r' or val == 'u' or val == 'v' or val == 'x' or val == 'y' or val == 'z')
servo1.write(up);
delay(15);
delay(5000);
servo1.write(down);
delay(15);
if(val == 'b' or val== 'f' or val== 'g' or val== 'h' or val== 'i' or val== 'j' or val== 'l' or val== 'p' or val== 'q' or val== 'r' or val== 's' or val== 't' or val== 'v' or val== 'w')
servo2.write(up);
delay(15);
delay(5000);
servo2.write(down);
delay(15);
if(val == 'k' or val == 'l' or val== 'm' or val== 'n' or val== 'o' or val== 'p' or val== 'q' or val== 'r' or val== 's' or val== 't' or val== 'u' or val== 'v' or val== 'x' or val== 'y' or val== 'z')
servo3.write(up);
delay(15);
delay(5000);
servo3.write(down);
delay(15);
if(val == 'c' or val == 'd' or val == 'f' or val == 'g' or val == 'i' or val == 'j' or val == 'm' or val == 'n' or val == 'p' or val == 'q' or val == 's' or val == 't' or val == 'w' or val == 'x' or val == 'y')
servo4.write(up);
delay(15);
delay(5000);
servo4.write(down);
delay(15);
if(val == 'd' or val == 'e' or val == 'g' or val == 'h' or val == 'j' or val == 'n' or val == 'o' or val == 'q' or val == 'r' or val == 't' or val == 'w' or val == 'y' or val == 'z')
servo5.write(up);
delay(15);
delay(5000);
servo5.write(down);
delay(15);
if(val == 'u' or val == 'v' or val == 'w' or val == 'x' or val == 'y' or val == 'z')
servo6.write(up);
delay(15);
delay(5000);
servo6.write(down);
delay(15);
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
You are moving one servo, delaying 5000mS, moving the next servo, delaying another 5000mS, etc.
Rearrange the if statements so that you move all the servos, then delay the 5000mS, then move all the servos back to the down position together at the end. Get rid of the 15mS delay inside the if statements, and just add that to the 5000mS delay.
The if statements are very lengthy, shorter to do something like this:
//if (val == 'a' or val == 'b' or val == 'c' or val == 'd' or val == 'e' or val == 'f' or val == 'g' or val == 'h' or val == 'k' or val == 'l' or val == 'm' or val == 'n' or val == 'o' or val == 'p' or val == 'q' or val == 'r' or val == 'u' or val == 'v' or val == 'x' or val == 'y' or val == 'z')
if (strchr("abcdefghklmnopqruvxyz", val) != NULL) //checks to see if val is somewhere within the quoted text
By removing almost all the delays, it does work a little.
// For: https://forum.arduino.cc/t/servos-dont-rotate-at-the-same-time/1057090
// Добавя се библиотеката на серво моторите
#include <Servo.h>
// Даваме индентифиционен номер/име на серво моторите
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
int val;
int down = 0;
int up = 90;
servo1.attach (3);
servo2.attach (5);
servo3.attach (6);
servo4.attach (9);
servo5.attach (10);
servo6.attach (11);
servo1.write(down);
servo2.write(down);
servo3.write(down);
servo4.write(down);
servo5.write(down);
servo6.write(down);
val = Serial.read(); // then read the serial value
servo1.write(up);
if (val == 'b' or val == 'f' or val == 'g' or val == 'h' or val == 'i' or val == 'j' or val == 'l' or val == 'p' or val == 'q' or val == 'r' or val == 's' or val == 't' or val == 'v' or val == 'w')
servo2.write(up);
if (val == 'k' or val == 'l' or val == 'm' or val == 'n' or val == 'o' or val == 'p' or val == 'q' or val == 'r' or val == 's' or val == 't' or val == 'u' or val == 'v' or val == 'x' or val == 'y' or val == 'z')
servo3.write(up);
if (val == 'c' or val == 'd' or val == 'f' or val == 'g' or val == 'i' or val == 'j' or val == 'm' or val == 'n' or val == 'p' or val == 'q' or val == 's' or val == 't' or val == 'w' or val == 'x' or val == 'y')
servo4.write(up);
if (val == 'd' or val == 'e' or val == 'g' or val == 'h' or val == 'j' or val == 'n' or val == 'o' or val == 'q' or val == 'r' or val == 't' or val == 'w' or val == 'y' or val == 'z')
servo5.write(up);
if (val == 'u' or val == 'v' or val == 'w' or val == 'x' or val == 'y' or val == 'z')
servo6.write(up);
delay(5000);
servo1.write(down);
servo2.write(down);
servo3.write(down);
servo4.write(down);
servo5.write(down);
servo6.write(down);
When you press 'b' only servo1 will move up, then there will be a 5 second delay before servo2 moves up. Follow the code through and you will see what I mean
You need a way if decoding which servos should move for each letter. This could be done with 26 if statements but would be clumsy at best, so don't do it
A suggestion. Declare a 2 dimensional array of bytes with one row for each letter of the alphabet numbered 0 to 25. In each row there will be 6 columns, one for each servo numbered 0 to 5. Put a 1 in any columns where the servo is required to move for the corresponding row letter and a zero where the servo should not move
Note that array indices start at 0 not 1 so the rows are numbered 0 to 25 and the columns are numbered 0 to 5
Define the array and post it here and I will take you through the next stage
