So this is the issue new to Arduino have a Arduino Uno board right now its powered off a 9v battery. I’ve attempted to use the sweep example set up a number of times on multiple different HiTec hs-485hb servos and for some reason they are not functioning. At most the servos move a fraction of an inch if anything. CC
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(30); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
