Servos not working with serial
Hi. I connected 2 servos to my Nano and I am controlling it with the serial monitor. Here is the code:
#include <Servo.h>
Servo servo1;
Servo servo2;
int val1;
int val2;
// put your setup code here, to run once
servo1.attach(9);
servo2.attach(10);
Serial.begin(57600);
Serial.println("Enter your values.");
while(Serial.available() == 0){}
val1 = Serial.parseInt();
val2 = Serial.parseInt();
servo1.write(val1);
servo2.write(val2);
Serial.print(val1);
Serial.print(", ");
Serial.println(val2);
However the servos are sometimes unresponsive.
I know this is a problem with the serial monitor rather than the servos because the servos sometimes work and sometimes don't.
And when I tried with the serial monitor on Arduino Cloud Editor, the serial monitor showed random characters like [ _ ! "
Please help because I don't know what to do.
while (Serial.available() == 0) {}
So, if there is at least 1 byte available read 2 bytes. Does that sound like good practice?
Try:
#include <Servo.h>
Servo servo1;
Servo servo2;
int val1;
int val2;
   servo1.attach(9);
   servo2.attach(10);
   Serial.println("Enter your values with a space between (ex. 123 456.");
   if (Serial.available() >= 2)
      servo1.write(val1);
      servo2.write(val2);
      Serial.print(val1);
      Serial.print(", ");
Set the line endings in serial monitor to "No line ending"
Or better yet, read the serial input basics tutorial for robust and non-blocking ways to read serial data (parseInt() is blocking).
See Arduino Software Solutions for various ways to read from Serial both blocking and non-blocking with their pros and cons.
