Servos stop running on arduino due
Hi I am currently using the arduino due and after sometime of usage the servos just stop working ,it seems that it stops sending pwm signals to the servos after a while ,can someone explain y this might happen ??
Are you powering the servos using a separate power supply? If not, that is almost certainly the problem.
Yes I am using a separate power supply
Then, to get informed help, it would be a good idea to read the "how to post" sticky, and follow directions. Post your code using code tags "# button".
