So in my quest to get more out of a 9v battery when trying to power two servos and a ton of LEDs, I bought a new very LDO voltage regulator, and some resistors which could handle up to 1 or 2 watts so I could supply around 300mA or so to each servo, and no more.
The voltage regulator worked great, and I'm getting like 3x the life out of the battery that I was with the LM317 I was using. This new one has a dropout of like 0.35v, though it still seems like it might be more than that, since my circuit goes kaput when the battery reads 7v when unconnected to the circuit.
But the resistors worked terribly. Even with the highest wattage resistor with the lowest resistance... just 15 ohms... when I stick one on each positive power lead to the servos, the servos buzz like crazy. They move just fine... but they buzz even when stationary.
The servos work just fine even when the battery is almost down to 7v, but as soon as I stick those resistors on there, even with a fresh battery, I get the buzz.
Any idea what might be causing that?
I mean if i stick a 15 ohm resistor on a 5v power source, I get 333mA out the other side, don't I? I'm pretty sure servos only need around 25mA when idle, and 100mA when moving but not loaded, as is the case here.
So what gives?
