ServoTimer1 lib
I just broke in my new arduino and wanted to play with a servo or two. I found the library "ServoTimer1" and placed it in the path ...\lib\targets\labraries, under it own folder.
When I try to compile the example sketch, I get the following error
"undefined refference to 'ServoTimer1::attach(int)'
with the following in the command line:
ServoTimer1.cpp: In static member function 'static void ServoTimer1::seizeTimer1()':
ServoTimer1.cpp:43: error: 'TICIE1' was not declared in this scope
o: In function setup': undefined reference to ServoTimer1::attach(int)'o: In function loop': o: In function __static_initialization_and_destruction_0(int, int)':
This is after I removed the servo.h file from ...\lib\targets\wiring as sugested elsewere under a different problem.
Is there anyone who can tell me what is wrong?
Regards
Ugilten
P.S. I run the IDE from the file "run.bat" since the "arduino.exe" does absolutely nothing on my labtop
Maybe you can find your answer in this thread.
Thanks
I must have missed that post some how
