ServoTimer2 and ping sensor gives me interuptions
hi all,
I’m currently working on a project where I want to rotate a Ping sensor using a servo. The servo should be constantly moving and the Ping sensor should be constantly measuring distance as well…
but I get a interuption (while the servo is moving the sensor is not working)
here is my code
int pingPin = 7;
int servoVal = 800
#include <ServoTimer2.h>
#define rollPin 10
ServoTimer2 servoRoll;
servoRoll.attach(rollPin);
readSerial();
servoRoll.write(servoVal);
long cm = microsecondsToCentimeters(pingTime());
if (cm < 255) {
pingOut = 0;
if (cm > 255) cm = 255;
Serial.print(“PI”);
Serial.print("=");
Serial.print(cm, BYTE);
Serial.println(";");
long microsecondsToCentimeters(long microseconds)
return microseconds / 29 / 2;
long pingTime(){
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
pinMode(pingPin, INPUT);
long duur = pulseIn(pingPin, HIGH);
return duur;
void readSerial() {
boolean validBytes = false;
if (Serial.available() > 0){
if (Serial.read() == ‘S’){ //first checker byte
if (Serial.read() == ‘E’){ //second checker byte
if (Serial.read() == ‘[’){ //third checker byte
servoVal = Serial.read();
if (servoVal && Serial.read() == ‘]’) {
validBytes = true;
servoVal = map(servoVal, 0, 255, 800, 2200);
if (validBytes == false) {
// dump invalid bytes
Serial.flush();
hope somebody can help.
Thanks,
Harm
