Set a variable 0 or 1 with an IF just once at the beginning
I want to set one variable called “salida1” with a 0 or a 1 depending on the start value of another variable called “Limit01”. I tried to use the following code to change the variable “salida1” to 1 if “Limit01” is in HIGH position at the beginning.
  • I’m using a button to move a stepper up and down, the problem is that I have a limit switch and the bottom and IF the program runs in this position, pressing this limit switch (HIGH), I want my starting value of “salida1” = 1.
#include <AccelStepper.h>
AccelStepper stepper(1, 9, 8);
float recorridoSubida = 135.0;
float pasosPorVuelta = 1600.0;
float pasoUsillo = 1.0;
float recorridoMax = 140.0;
float pos1 = (pasosPorVuelta * recorridoMax) * pasoUsillo;
float pos2 = - (pasosPorVuelta * recorridoSubida) * pasoUsillo;
int estado1 = 0;
int estadoAnterior1 = 0;
int salida1 = 0;
#define Limit01 2 // Creamos el fin de carrera conectado en el pin 2
pinMode(10, INPUT);
pinMode(Limit01, INPUT);
digitalWrite(Limit01, LOW);
if (digitalRead(Limit01) == HIGH) { **
** digitalWrite(salida1,HIGH);
Serial.print(digitalRead(Limit01));
Serial.print("\t");
Serial.print(salida1);
Serial.print("\t");
stepper.setMaxSpeed(32000);
stepper.setSpeed(16000);
stepper.setAcceleration(1000);
float posicionActual = stepper.currentPosition();
estado1 = digitalRead(10);
if ((estado1 == HIGH) && (estadoAnterior1 == LOW)) {
salida1 = 1 - salida1;
estadoAnterior1 = estado1;
if (salida1 == 1) {
if (digitalRead(Limit01) == LOW) {
stepper.moveTo(pos1);
stepper.run();
else {
stepper.setCurrentPosition(pos1);
if ((salida1 == 0) && (digitalRead(Limit01) == HIGH)){
stepper.move(pos2);
stepper.run();
else{
stepper.run();
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What pin do you have the limit switch connected to?
Tom… :slight_smile:
  • I have My limit switch connected to digitalpin 2, and it is called Limit01
int estado1 = 0;
int salida1 = 0;
   pinMode(10, INPUT);
   Serial.print("\t");
   Serial.print("\t");
  if (salida1 == 1) {
        stepper.run();
    else {
         stepper.move(pos2);
         stepper.run();
  else{
         stepper.run();
Why do you digitalWrite LOW to the input?
How have you got the limit wired?
Tom… :slight_smile:
Here you have my skematich, I dont use the same driver, the driver Im using is 2H Microstep driver DQ20MA, because of that I just connect two pins the direction and the step.
The digitalWrite to an INPUT was an error.
Thank you,
OPs Fritzy
Tom… :o
Hi, Do you have a DMM? Check the voltages around the edges of the protoboard, some boards have the long side conductors open circuit halfway along the length.
What are the spec/data on your stepper, I hope you are not using the UNO to provide current to it?
Tom.... :)
Hi Tom,
I am new in arduino and I dont know how to make the skematich with this program.
My stepper is already moving, my problem is with the code, as I told you in the first post I want to know how to includ a if in the setupvoid. I want to know how to torn my estado1 to 1 if the limit switch is HIGH at the beggining of the program.
Thank you
Hi, What does your monitor show ?
Try it with the limit switch in each OFF and ON position.
Tom... :)
