set accessbits mifare 1kb cards
I have a question about setting up accessbits 1kb mifare cards.(i use arduino and MFRC522)
as you can see in the below picture, I wrote the value of each of the blocks
C10=0 ,C20=1 ,C30=1 >>>block 0
C11=0 ,C21=1 ,C31=1 >>>block 1
C12=0 ,C22=1 ,C32=1 >>>block 2
C13=1 ,C23=1 ,C33=1 >>>block 3 (Trailer)
byte6 = 0b00000111 >>hex= 0x07 >>byte= 7
byte7 = 0b10000000 >>hex= 0x80 >>byte= 128
byte8 = 0b11111111 >>hex= 0xFF >>byte= 255
now i want to setup this function in MFRC522 library Arduino:
byte trailerBuffer[] = {
255 ,255 ,255 ,255 ,255 ,255, // Keep default key A
7, 128, 255,
0,
255 ,255 ,255 ,255 ,255 ,255 // Keep default key B
mfrc522.MIFARE_SetAccessBits(&trailerBuffer[6], g0, g1, g2, g3);
what are the values of (g0, g1, g2, g3) for these blocks?
Thanks for your attention
Your duplicate post in another forum section has been deleted
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
