// Set all pins as output
for(int i=2; i<=9; i++) {
pinMode(i, OUTPUT);
I found this online, and trying to reverse engineer this. Can someone explain how it turns pins on? I was originally going to list each individual pin as output but thought there was an easier way to do this.
My ultimate goal is to turn digital pins 2 - 13 and A0 - A5 pins as output in the void setup
Also, you wonder how to set all pins as outputs in an easier way than actually coding them one-by-one?
Can't help you with that last one, but explaining the for-loop is simple.
Can’t help you with that last one, but explaining the for-loop is simple.
Yes I want to know how the loop works.
for(int i=2; i<=19; i++) {
for the second part, here’s what I have. I already have these defined to specific pins.
Test at top, test at bottom, where is not really important. Idea was to show the 3 steps + action being done - initialize, perform action, increment, test.
Yes, it absolutely is!
Test at bottom (do...while) will always execute the body of the loop at least once.
Test at the top (while...) may not execute the body of the loop at all.
for(condition == true)
//Here the code to execute repeatedly (looping) while the for condition is true
example here uses uint8_t for the numircal value, which is a number between 0 and 255
uint8_t counterValue = 1; // define initial value
uint8_t maxValue = 10; // define max value
for(counterValue < maxValue) { //Clear example
Serial.println(counterValue); // Print the counter value to serial
counterValue++; // Each time loop is true, add 1 to counter value
++ behind a numerical variable name increases it with 1, – behind a numerical value decreases it with 1.
Think about that - why would you initialize a for loop that you never intended to run?
I don't care if you wrote it this way instead:
i = 2;
if (i > 19){ goto end}
pinMode (i, OUTPUT);
i=i+1;
end
Often you don't know in advance (though not here, obviously) if the loop is intended to run or not - empty list or string handling come to mind.
Dereferencing an invalid or null pointer in a do..while might be catastrophic.
Lennaert:
Command names aren't like animal species. They're just conveniences for programmers.
Please note that what Arduino source code is compiled into is the reality. There is no for-loop in AVR.
All that for-loop is is a while loop with built-in counter. That's it.
You've managed to degrade a for-loop down to a while-loop, not do some kind of magic.
Sometimes an example says more than many times as many words.
And other times, some comments can really help.
Sorry. I usually don't comment the obvious.
But then I also consider the code to be the real comments.
I'm just showing how loop() can serve where nested while-loops or for-loops would do.
The thing is that when I write event code, I try to avoid while and for loops, especially nested, that block timing.
This is an example of how that is done, just to show that nobody HAS to do it in some learned way.
It's a bit like saying don't use an int where a byte will do just because you "grew up" using int.
Funny thing though... it's a bit like the principle of what you've been showing earlier in this thread.
