Set arduino slave address using dip switch (I2C)
hi,
i have do some program to make the slave read the dip switch, to set the slave address using dip switch.
but nothing happen at slave (it’s like the slave not read from dip switch for the address setting).
how to set the arduino slave address using dip switch?
thank you
slave program:-
#include <Wire.h>
#define LED_OUT 13
#define ADD 10                                                            // address initial
int ADDRESS;
int a = 0;        // pin that configure 1 or 0 for hardware setting
int button;
  pinMode(LED_OUT, OUTPUT);
  digitalWrite(LED_OUT,LOW);
  pinMode(a, INPUT);                                                      // read from dip switch, for address hardware setting
  button = digitalRead(a);
  ADDRESS = ADD + button;
  Wire.begin(ADDRESS);
  Wire.onReceive(receiveEvent);
void receiveEvent(int howMany){
  while (Wire.available() > 0){
    boolean b = Wire.receive();
    Serial.print(b, DEC);
    digitalWrite(LED_OUT, b);
master program:-
#include <Wire.h>
#define BUTTON 10
#define ADDRESS 11                                            //address setting for slave,
  Serial.begin(9600);           // start serial for output
  pinMode(BUTTON, INPUT);
  digitalWrite(ADDRESS, HIGH);
  Wire.begin();
boolean last_state = HIGH;
int button_state = digitalRead(BUTTON);
  if (button_state != last_state){
    last_state = button_state;
    Serial.println("Start");
    Wire.beginTransmission(ADDRESS);
    Serial.println("Beginning transmission");
    Wire.send(button_state);
    Serial.println("Sent Data");
    Wire.endTransmission();
    Serial.println("Ended transmission");
How have you wired up this switch, exactly?
i just use one dip switch only at slave for testing. pin 0 = for set the add "1" or "0" at slave address.
Pin 0 is one of the serial pins. You also have Serial.begin() in setup(). I know that the Serial.begin() comes after you read the switch, but, it is better if you use some other pin.
PaulS is right. Pin 0 has a pull-up on it from the USB chip. Better choose D2 onwards.
i already change the pin to pin D3,
the situation is :-
1- the dip switch on at first starting:- the Address=11, ADD(contain 10) will + with 1 bit from dip switch, so the led will on when the push button is press at arduino master, and the led will off when button released at arduino master. But when the dip switch if change to off condition the led still can on/off even the bit value turn to 0 because the dip switch off.
2- the dip switch off at first starting:- the Address=10,ADD(contain 10) will + with 0 from dip switch, the led will off at first, but cannot turn on even the dip switch change to on
it's mean the arduino master/slave will remember the first memory address, and cannot change even we change the value,
tsudakazuki:
You’ve lost me there. You only test the switch once.
And now, can i change the input bit to binary?
What does this mean? You read a value from a digital pin. You got either 0 or 1. Looks like binary to me.
int btn1;          //button 1
What does this mean? Is this a pin number? It doesn't make sense as the value of a pin. Use a more meaningful name.
int ADDRESS;
By convention, all capital letters in a name mean that the name was #define'd into existence.
//#define ADD 10
  ADDRESS = ADD + btn1;
This isn't going to compile. Don't post code that won't compile. It wastes everyone's time.
Below is an example of reading a hex switch, this can be duplicated with 4 switches to count up to 16 (0-15 or 0x00 to 0x0F) Probably a better way of doing it but it works. (switches are pulled to 5v when "off")
const byte Mode_Sel_1 = 2;
const byte Mode_Sel_2 = 3;
const byte Mode_Sel_3 = 4;
const byte Mode_Sel_4 = 5;
byte getMODE(){
  boolean _1;
  boolean _2;
  boolean _3;
  boolean _4;
  _1 = digitalRead(Mode_Sel_1);
  _2 = digitalRead(Mode_Sel_2);
  _3 = digitalRead(Mode_Sel_3);
  _4 = digitalRead(Mode_Sel_4);
  if (_1 && _2 && _3 && _4){
    return 0x00;
  else if (!_1 && _2 && _3 && _4){
    return 0x01;
  else if (_1 && !_2 && _3 && _4){
    return 0x02;
  else if (!_1 && !_2 && _3 && _4){
    return 0x03;
  else if (_1 && _2 && !_3 && _4){
    return 0x04;
  else if (!_1 && _2 && !_3 && _4){
    return 0x05;
  else if (_1 && !_2 && !_3 && _4){
    return 0x06;
  else if (!_1 && !_2 && !_3 && _4){
    return 0x07;
  else if (_1 && _2 && _3 && !_4){
    return 0x08;
  else if (!_1 && _2 && _3 && !_4){
    return 0x09;
  else if (_1 && !_2 && _3 && !_4){
    return 0x0A;
  else if (!_1 && !_2 && _3 && !_4){
    return 0x0B;
  else if (_1 && _2 && !_3 && !_4){
    return 0x0C;
  else if (!_1 && _2 && !_3 && !_4){
    return 0x0D;
  else if (_1 && !_2 && !_3 && !_4){
    return 0x0E;
  else if (!_1 && !_2 && !_3 && !_4){
    return 0x0F;
