Set Contents of Struct After Initialization
I am creating a struct stored in a variable with the following code:
struct Options {
  unsigned int COLOR_RED;
  unsigned int COLOR_GREEN;
  unsigned int COLOR_BLUE;
  unsigned int COLOR_BLACK;
  unsigned int COLOR_YELLOW;
  unsigned int COLOR_WHITE;
  unsigned int COLOR_ORANGE;
  unsigned int COLOR_CYAN;
  unsigned int COLOR_BRIGHT_RED;
  unsigned int COLOR_LIGHT_GRAY;
  unsigned int COLOR_DARK_GRAY;
  unsigned int DEFAULT_BACK_COLOR;
  String SD_PATH;
  String SD_PATH_SETTINGS;
Options options;
However, when I try to set it from somewhere later in the program with this code: (optionInt is being set from the value of a text file)
unsigned int optionInt = 5; // just an example of what it could be
options.COLOR_RED = optionInt;
It comes up with this error:
request for member 'COLOR_RED' in 'options', which is of non-class type 'String[50]'.
Why is this happening and how can I fix it? Thanks!
For example, is this possible
Yes. That's exactly how to populate a struct instance.
PaulS:
Check the modifications to the OP. Why is it coming up with this error?
You didn't show the code that is causing the error, so how should we know? What I can tell you is that the compiler is right. Even when it's wrong, it's right. You do have to do it it's way.
PaulS:
There, I have added the code that is being used.
It is fine how you have it there. Seems there is some conflicting code you haven't posted.
Do you have this line below anywhere?
String options[50];
pYro_65:
Oh wow I can't believe I missed that! Thanks for the help!
