Set cursor in string?
I'm trying to figure this for couple of hours with no luck. I have a string which can hold some data at specific places. For example, three variables A, B and C and their values (no more than 999):
"a100 b20 c300"
Now, depending on some parameters which aren't important here, neither of those variables actually need to be in string, but their position must be constant (they have fixed length of 4). So, if for example b isn't there, same string would look like this:
"a100 c300"
Or it can change value:
"a100 b250 c300"
I know specific location of each variable. How do I set string cursor to location of b, or any other place actually so that I can replace it?
I am not sure what you mean by setting a cursor in a string.
The following will replace 4 characters in a string.
    int pos = 5;
    for (int i = 0; i < 4; i++)
        myString[i + pos] = newString[i];
    Serial.println(myString);
    delay(10000);
A string is just an array of char variables. If you want to modify certain positions then you address them in the string by index. There is no cursor nor any similar concept involved.
Google "C++ array" and you should find plenty of tutorials that explain how to work with them.
Go here
Scroll down until you find
State Machine
Another way of processing incoming data, without blocking, is to set up a "state machine". Effectively this means looking at each byte in the input stream, and handling it depending on the current state.
As an example, say you had this coming into the serial port:
R4500S80G3
Where Rnnn is RPM, Snnnn is speed, and Gnnnn is the gear setting.
The state machine below switches state when it gets a letter "R", "S" or "G". Otherwise it processes incoming digits by multiplying the previous result by 10, and adding in the new one.
When switching states, if first handles the previous state. So for example, after getting R4500 when the "S" arrives, we call the ProcessRPM function, passing it 4500.
This has the advantage of handling long messages without even needing any buffer, thus saving RAM. You can also process message as soon as the state changes, rather than waiting for end-of-line.
And once you've seen that, how should your encoding work?
Not sure what you are working on, but the below code captures serial input data packets as a String, then the desired device and a numeric value are extracted from the captured String.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or combined like 30c,180b,70a,120d,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
