I am making a drive for BLDC motor with IRF3710 MOSFET and controller as arduino UNO. I want to increase the switching frequency to above 5 kHZ in all pwm pins. Does anyone have the code for it?
This will get you a 7.8 KHz PWM on Timer2 (Pin B3) in FastPWM mode
OCR2A will determine your duty cycle.
* URL: https://dbuezas.github.io/arduino-web-timers/#mcu=ATMEGA328P&timer=2&timerMode=FPWM&CompareOutputModeA=clear-on-match%2C+set-at-max&OCR2A=137&clockPrescalerOrSource=8
* Mode : FPWM
* Period : 128 us
* Frequency: 7.8125 kHz
* Outputs :
* - B3: 53.52%, clear-on-match, set-at-max
void setup(){
noInterrupts();
TCCR2A =
1 << COM2A1 |
1 << WGM21 |
1 << WGM20;
TCCR2B =
1 << CS21;
DDRB =
1 << DDB3;
OCR2A = 136;
interrupts();
