Hello everyone!
I am new here and having issues setting the time on my Arduino mega 2560. At one point it was working but I went to change my timezone and now all it says is Local Time: 5:0:0 1/1/0 Day_of_week:1 when I check the serial monitor.
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68
const int SetTimeButtonPin = 12;
int SetTime = 0;//Set this variable to 1 to set the time without a button.
float timezone = -5;//Give your timezone here for double checking against GMT.
byte Set_Second = 0;
byte Set_Minute = 53;
byte Set_Hour = 11;
byte Set_DayOfMonth = 22;
byte Set_Month = 7;
byte Set_Year = 12;
byte Set_DayOfWeek = 1;
void setup(){
Wire.begin();
pinMode(SetTimeButtonPin, INPUT);
if (SetTime==1){
setDateDs1307(Set_Second, Set_Minute, Set_Hour, Set_DayOfWeek, Set_DayOfMonth, Set_Month, Set_Year);
void loop(){
if (digitalRead(SetTimeButtonPin)==HIGH && SetTime == 0){
Serial.println("Time Has Been Set");
delay(3000);
byte secondRTC, minuteRTC, hourRTC, dayOfWeekRTC, dayOfMonthRTC, monthRTC, yearRTC;
getDateDs1307(&secondRTC, &minuteRTC, &hourRTC, &dayOfWeekRTC, &dayOfMonthRTC, &monthRTC, &yearRTC);
Serial.print("Local Time: ");
printtime(hourRTC, minuteRTC, secondRTC, monthRTC, dayOfMonthRTC, yearRTC, dayOfWeekRTC, 0);//Displays the local time
Serial.print("GMT: ");
printtime(hourRTC, minuteRTC, secondRTC, monthRTC, dayOfMonthRTC, yearRTC, dayOfWeekRTC, 1);//Displays the time at the prime meridian.
Serial.println(" ");
delayInMillis(1000);
void delayInMillis(long delayInMicrosec){
long t1,t2;
t1=millis();
t2=millis();
while ((t1+delayInMicrosec)>t2){t2=millis();
if (t2<t1){t2=t1+delayInMicrosec+1;}//Check if micros() rolled over
if (digitalRead(SetTimeButtonPin)==HIGH){break;}
// Maurice Ribble
// 4-17-2008
// http://www.glacialwanderer.com/hobbyrobotics
// This code tests the DS1307 Real Time clock on the Arduino board.
// The ds1307 works in binary coded decimal or BCD. You can look up
// bcd in google if you aren't familior with it. There can output
// a square wave, but I don't expose that in this code. See the
// ds1307 for it's full capabilities.
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
// Stops the DS1307, but it has the side effect of setting seconds to 0
// Probably only want to use this for testing
/*void stopDs1307()
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.write(0);
Wire.write(0x80);
Wire.endTransmission();
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers
void setDateDs1307(byte second, // 0-59
byte minute, // 0-59
byte hour, // 1-23
byte dayOfWeek, // 1-7
byte dayOfMonth, // 1-28/29/30/31
byte month, // 1-12
byte year) // 0-99
Wire.write((byte)0);
Wire.write((byte)decToBcd(second)); // 0 to bit 7 starts the clock
Wire.write((byte)decToBcd(minute));
Wire.write((byte)decToBcd(hour)); // If you want 12 hour am/pm you need to set
// bit 6 (also need to change readDateDs1307)
Wire.write((byte)decToBcd(dayOfWeek));
Wire.write((byte)decToBcd(dayOfMonth));
Wire.write((byte)decToBcd(month));
Wire.write((byte)decToBcd(year));
// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
// Reset the register pointer
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
// A few of these need masks because certain bits are control bits
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f); // Need to change this if 12 hour am/pm
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
void printtime(int hour, int minute, int second, int month, int dayOfMonth, int year, int dayOfWeek, int GMT_YorN){
if (GMT_YorN==1){hour = hour - timezone;//Note: Timezone is a global variable
if (hour<0){hour = hour + 24;}
if (hour>=24){hour=hour-24;}
Serial.print(hour, DEC);
Serial.print(":");
Serial.print(minute, DEC);
Serial.print(":");
Serial.print(second, DEC);
Serial.print(" ");
if (GMT_YorN!=1){
Serial.print(month, DEC);
Serial.print("/");
Serial.print(dayOfMonth, DEC);
Serial.print("/");
Serial.print(year, DEC);
Serial.print(" Day_of_week:");
Serial.println(dayOfWeek, DEC);
I'm using the mega 25620 and Arduino Sun Harvester Shield V2 if anyone is familiar with "The Open Sun Harvesting Project" https://www.cerebralmeltdown.com/open-sun-harvesting-project
Thanks!
Set_RTC_Time.ino (4.96 KB)
