Set scrolling speed on LED dot matrix display
Using ESP8266 D1 and LED dot matrix displays.
Everything working OK with the sketch below but I want to slow the scrolling down a bit but I can't find (I'm a newbie) anything in the sketch that references speed. Is there anything I can change or add to the sketch to control the scrolling speed?
(I've removed my SSID and password)
[code]
#include <ESP8266WiFi.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#define PRINT_CALLBACK 0
#define DEBUG 0
#define LED_HEARTBEAT 0
#if DEBUG
#define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
#define PRINTS(s)   { Serial.print(F(s)); }
#else
#define PRINT(s, v)
#define PRINTS(s)
#endif
#if LED_HEARTBEAT
#define HB_LED  D2
#define HB_LED_TIME 500 // in milliseconds
#endif
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define MAX_DEVICES 4
#define CLK_PIN   D5
#define DATA_PIN  D7
#define CS_PIN    D8
// SPI hardware interface
// MD_MAX72XX mx = MD_MAX72XX(CS_PIN, MAX_DEVICES);
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW  //edit this as per your LED matrix hardware type
MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// MD_MAX72XX mx = MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// WiFi login parameters - network name and password
const char* ssid = "";                   // edit your wifi SSID here
const char* password = "";            // edit your wifi password here
// WiFi Server object and parameters
WiFiServer server(80);
// Global message buffers shared by Wifi and Scrolling functions
const uint8_t MESG_SIZE = 255;
const uint8_t CHAR_SPACING = 1;
const uint8_t SCROLL_DELAY = 75;
char curMessage[MESG_SIZE];
char newMessage[MESG_SIZE];
bool newMessageAvailable = false;
char WebResponse[] = "HTTP/1.1 200 OK\nContent-Type: text/html\n\n";
char WebPage[] =
"<!DOCTYPE html>" \
"<html>" \
"<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">" \
"<title>LED Matrix Display</title>" \
"<style>" \
"html, body" \
"font-family: Helvetica; "\
"display: block;"\
"margin: 0px auto;"\
"text-align: center;"\
"background-color: #f5f5f5;" \
"#container " \
"width: device-width;" \
"height: device-height;" \
"margin-left: 5px;" \
"margin-top: 20px;" \
"border: solid 2px;" \
"padding: 10px;" \
"background-color: #00FFFF;" \
"</style>"\
"<script>" \
"strLine = \"\";" \
"function SendText()" \
"  nocache = \"/&nocache=\" + Math.random() * 1000000;" \
"  var request = new XMLHttpRequest();" \
"  strLine = \"&MSG=\" + document.getElementById(\"txt_form\").Message.value;" \
"  request.open(\"GET\", strLine + nocache, false);" \
"  request.send(null);" \
"</script>" \
"</head>" \
"<body>" \
"<H1><b>LED Matrix WiFi Control</b></H1>" \
"<div id=\"container\">"\
"<form id=\"txt_form\" name=\"frmText\">" \
"<label><b>MESSAGE : </b><input type=\"text\" name=\"Message\" maxlength=\"255\"></label>%ltbr><br>" \
"</form>" \
"<br>" \
"<input type=\"submit\" value=\"SEND\" onclick=\"SendText()\">" \
"</div>" \
"</body>" \
"</html>";
char *err2Str(wl_status_t code)
  switch (code)
  case WL_IDLE_STATUS:    return("IDLE");           break; // WiFi is in process of changing between statuses
  case WL_NO_SSID_AVAIL:  return("NO_SSID_AVAIL");  break; // case configured SSID cannot be reached
  case WL_CONNECTED:      return("CONNECTED");      break; // successful connection is established
  case WL_CONNECT_FAILED: return("CONNECT_FAILED"); break; // password is incorrect
  case WL_DISCONNECTED:   return("CONNECT_FAILED"); break; // module is not configured in station mode
  default: return("??");
uint8_t htoi(char c)
  c = toupper(c);
  if ((c >= '0') && (c <= '9')) return(c - '0');
  if ((c >= 'A') && (c <= 'F')) return(c - 'A' + 0xa);
  return(0);
boolean getText(char *szMesg, char *psz, uint8_t len)
  boolean isValid = false;  // text received flag
  char *pStart, *pEnd;      // pointer to start and end of text
  // get pointer to the beginning of the text
  pStart = strstr(szMesg, "/&MSG=");
  if (pStart != NULL)
    pStart += 6;  // skip to start of data
    pEnd = strstr(pStart, "/&");
    if (pEnd != NULL)
      while (pStart != pEnd)
        if ((*pStart == '%') && isdigit(*(pStart+1)))
          // replace %xx hex code with the ASCII character
          char c = 0;
          pStart++;
          c += (htoi(*pStart++) << 4);
          c += htoi(*pStart++);
          *psz++ = c;
          *psz++ = *pStart++;
      *psz = '\0'; // terminate the string
      isValid = true;
  return(isValid);
void handleWiFi(void)
  static enum { S_IDLE, S_WAIT_CONN, S_READ, S_EXTRACT, S_RESPONSE, S_DISCONN } state = S_IDLE;
  static char szBuf[1024];
  static uint16_t idxBuf = 0;
  static WiFiClient client;
  static uint32_t timeStart;
  switch (state)
  case S_IDLE:   // initialise
    PRINTS("\nS_IDLE");
    idxBuf = 0;
    state = S_WAIT_CONN;
  case S_WAIT_CONN:   // waiting for connection
      client = server.available();
      if (!client) break;
      if (!client.connected()) break;
#if DEBUG
      char szTxt[20];
      sprintf(szTxt, "%03d:%03d:%03d:%03d", client.remoteIP()[0], client.remoteIP()[1], client.remoteIP()[2], client.remoteIP()[3]);
      PRINT("\nNew client @ ", szTxt);
#endif
      timeStart = millis();
      state = S_READ;
  case S_READ: // get the first line of data
    PRINTS("\nS_READ");
    while (client.available())
      char c = client.read();
      if ((c == '\r') || (c == '\n'))
        szBuf[idxBuf] = '\0';
        client.flush();
        PRINT("\nRecv: ", szBuf);
        state = S_EXTRACT;
        szBuf[idxBuf++] = (char)c;
    if (millis() - timeStart > 1000)
      PRINTS("\nWait timeout");
      state = S_DISCONN;
  case S_EXTRACT: // extract data
    PRINTS("\nS_EXTRACT");
    // Extract the string from the message if there is one
    newMessageAvailable = getText(szBuf, newMessage, MESG_SIZE);
    PRINT("\nNew Msg: ", newMessage);
    state = S_RESPONSE;
  case S_RESPONSE: // send the response to the client
    PRINTS("\nS_RESPONSE");
    // Return the response to the client (web page)
    client.print(WebResponse);
    client.print(WebPage);
    state = S_DISCONN;
  case S_DISCONN: // disconnect client
    PRINTS("\nS_DISCONN");
    client.flush();
    client.stop();
    state = S_IDLE;
  default:  state = S_IDLE;
void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col)
// Callback function for data that is being scrolled off the display
#if PRINT_CALLBACK
  Serial.print("\n cb ");
  Serial.print(dev);
  Serial.print(' ');
  Serial.print(t);
  Serial.print(' ');
  Serial.println(col);
#endif
uint8_t scrollDataSource(uint8_t dev, MD_MAX72XX::transformType_t t)
// Callback function for data that is required for scrolling into the display
  static enum { S_IDLE, S_NEXT_CHAR, S_SHOW_CHAR, S_SHOW_SPACE } state = S_IDLE;
  static char   *p;
  static uint16_t curLen, showLen;
  static uint8_t  cBuf[8];
  uint8_t colData = 0;
  // finite state machine to control what we do on the callback
  switch (state)
  case S_IDLE: // reset the message pointer and check for new message to load
    PRINTS("\nS_IDLE");
    p = curMessage;      // reset the pointer to start of message
    if (newMessageAvailable)  // there is a new message waiting
      strcpy(curMessage, newMessage); // copy it in
    state = S_NEXT_CHAR;
  case S_NEXT_CHAR: // Load the next character from the font table
    PRINTS("\nS_NEXT_CHAR");
    if (*p == '\0')
      state = S_IDLE;
      showLen = mx.getChar(*p++, sizeof(cBuf) / sizeof(cBuf[0]), cBuf);
      curLen = 0;
      state = S_SHOW_CHAR;
  case S_SHOW_CHAR: // display the next part of the character
    PRINTS("\nS_SHOW_CHAR");
    colData = cBuf[curLen++];
    if (curLen < showLen)
    // set up the inter character spacing
    showLen = (*p != '\0' ? CHAR_SPACING : (MAX_DEVICES*COL_SIZE)/2);
    curLen = 0;
    state = S_SHOW_SPACE;
    // fall through
  case S_SHOW_SPACE:  // display inter-character spacing (blank column)
    PRINT("\nS_ICSPACE: ", curLen);
    PRINT("/", showLen);
    curLen++;
    if (curLen == showLen)
  default:
    state = S_IDLE;
  return(colData);
void scrollText(void)
  static uint32_t prevTime = 0;
  // Is it time to scroll the text?
  if (millis() - prevTime >= SCROLL_DELAY)
    mx.transform(MD_MAX72XX::TSL);  // scroll along - the callback will load all the data
    prevTime = millis();      // starting point for next time
#if DEBUG
  PRINTS("\n[LED Matrix WiFi Message Display]\nType a Message For The Scrolling Display From Your Browser.");
#endif
#if LED_HEARTBEAT
  pinMode(HB_LED, OUTPUT);
  digitalWrite(HB_LED, LOW);
#endif
  // Display initialisation
  mx.begin();
  mx.setShiftDataInCallback(scrollDataSource);
  mx.setShiftDataOutCallback(scrollDataSink);
  curMessage[0] = newMessage[0] = '\0';
  // Connect to and initialise WiFi network
  PRINT("\nConnecting to ", ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    PRINT("\n", err2Str(WiFi.status()));
  PRINTS("\nWiFi Connected.");
  // Start the server
  server.begin();
  PRINTS("\nServer Started.");
  // Set up first message as the IP address
  sprintf(curMessage, "%03d:%03d:%03d:%03d", WiFi.localIP()[0], WiFi.localIP()[1], WiFi.localIP()[2], WiFi.localIP()[3]);
  PRINT("\nAssigned IP ", curMessage);
#if LED_HEARTBEAT
  static uint32_t timeLast = 0;
  if (millis() - timeLast >= HB_LED_TIME)
    digitalWrite(HB_LED, digitalRead(HB_LED) == LOW ? HIGH : LOW);
    timeLast = millis();
#endif
  handleWiFi();
  scrollText();
[/code]
I guess SCROLL_DELAY is what you're looking. Increasing that value will slow down the text scrolling.
Try to change SCROLL_DELAY from 75 to 1000 to see if it really have an effect. Otherwise I also do not see anything else.
OK, I'll try that and see if it slows down the horizontal scrolling or just increases the time in between the text rescrolling.
Thanks.
OK- it worked! I started by bumping it up to something like 200, then 400, then 800. 800 made it even faster than the original 75 setting so I settled on 500 and that seems fine.
Many thanks to all.
const uint8_t SCROLL_DELAY = 500;  /*Try changing this number.  Originally 75*/
Happy to hear it. Enjoy it. best regards
