Set Static IP for connected Devices // MKR WiFi 1010
Hello Forum,
im trying to build an Access Point with a MKR WiFi 1010 Module and distribute static IP Adresses
for the connected Devices.
Im currently running the AP_SimpleWebServer Example.
Can anyone please Help out?
  WiFi Web Server LED Blink
  A simple web server that lets you blink an LED via the web.
  This sketch will create a new access point (with no password).
  It will then launch a new server and print out the IP address
  to the Serial monitor. From there, you can open that address in a web browser
  to turn on and off the LED on pin 13.
  If the IP address of your board is yourAddress:
    http://yourAddress/H turns the LED on
    http://yourAddress/L turns it off
  created 25 Nov 2012
  by Tom Igoe
  adapted to WiFi AP by Adafruit
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;                // your network key Index number (needed only for WEP)
int led =  LED_BUILTIN;
int status = WL_IDLE_STATUS;
WiFiServer server(80);
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Access Point Web Server");
  pinMode(led, OUTPUT);      // set the LED pin mode
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < "1.0.0") {
    Serial.println("Please upgrade the firmware");
  // by default the local IP address of will be 192.168.4.1
  // you can override it with the following:
  // WiFi.config(IPAddress(10, 0, 0, 1));
  // print the network name (SSID);
  Serial.print("Creating access point named: ");
  Serial.println(ssid);
  // Create open network. Change this line if you want to create an WEP network:
  status = WiFi.beginAP(ssid, pass);
  if (status != WL_AP_LISTENING) {
    Serial.println("Creating access point failed");
    // don't continue
    while (true);
  // wait 10 seconds for connection:
  delay(10000);
  // start the web server on port 80
  server.begin();
  // you're connected now, so print out the status
  printWiFiStatus();
  // compare the previous status to the current status
  if (status != WiFi.status()) {
    // it has changed update the variable
    status = WiFi.status();
    if (status == WL_AP_CONNECTED) {
      // a device has connected to the AP
      Serial.println("Device connected to AP");
      // a device has disconnected from the AP, and we are back in listening mode
      Serial.println("Device disconnected from AP");
  WiFiClient client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println("new client");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println();
            // the content of the HTTP response follows the header:
            client.print("Click <a href=\"/H\">here</a> turn the LED on
            client.print("Click <a href=\"/L\">here</a> turn the LED off
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
          else {      // if you got a newline, then clear currentLine:
            currentLine = "";
        else if (c != '\r') {    // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /H" or "GET /L":
        if (currentLine.endsWith("GET /H")) {
          digitalWrite(led, HIGH);               // GET /H turns the LED on
        if (currentLine.endsWith("GET /L")) {
          digitalWrite(led, LOW);                // GET /L turns the LED off
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void printWiFiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print where to go in a browser:
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
Best,
Mark
I managed to setup an Access Point and web pages using ESP8266 Thing Hookup Guide in the end used a Raspberry Pi with raspap-webgui
Hey Horace,
Yeah i've stumbled over the ESP8266 in my researches. The only reason i took the MKR wifi 1010 is because of the antenna. Main Focus relies on signal range and power.
Maybe i should try the "THING" too.
Thank you
