Set the default relay turn OFF state into 3 seconds
I have a problem where, after setting the time, the relay only lights its LED and makes a buzzing sound when the set time arrives. I think this is an issue in the code. Can you help me?
Objectives:
  • I want the relay to turn ON when the set time arrives
  • The relay should turn OFF after 3 seconds
#include <LiquidCrystal.h>
#include <EEPROM.h>
#include <virtuabotixRTC.h>
// Relay pin
#define relay1      10
// RTC module pins
#define rtcVCC      A5
#define rtcGND      A4
#define rtcSCLK     A3
#define rtcIO       A2
#define rtcCE       A1
// RTC object
virtuabotixRTC myRTC(rtcSCLK, rtcIO, rtcCE);
// Keypad
#define btnRIGHT    0
#define btnUP       1
#define btnDOWN     2
#define btnLEFT     3
#define btnSELECT   4
#define btnNONE     5
// Mode
#define modeSETUP   1
#define modeNORMAL  2
int mode = 1; // Default mode
// EEPROM addressing
#define adr1ON    2
#define adr2ON    6
#define adr3ON    10
#define adr4ON    14
#define adr5ON    18
#define adr6ON    22
#define adr7ON    26
#define adr8ON    30
byte name0x1[] = { B11111, B10000, B10000, B10100, B10110, B11111, B00110, B00100 };
byte name0x2[] = { B11000, B00100, B00010, B00010, B11010, B00010, B00100, B11000 };
byte name0x3[] = { B00011, B00100, B01001, B01001, B01001, B01000, B00100, B00011 };
// UP
byte name1x4[] = { B00000, B00100, B01110, B11111, B01110, B01110, B01110, B00000 };
// DOWN
byte name1x5[] = { B00000, B01110, B01110, B01110, B11111, B01110, B00100, B00000 };
int eepromMin = 0;
int eepromHour = 0;
int eepromHourON = 0;
int eepromMinON = 0;
// LCD keypad shield pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int lcd_key     = 0;
int adc_key_in  = 0;
  lcd.createChar(0, name0x1);
  lcd.createChar(1, name0x2);
  lcd.createChar(2, name0x3);
  lcd.createChar(3, name1x4);
  lcd.createChar(4, name1x5);
	// Set all digital pins as output
	for (int i = 0; i <= 13; i++) {
		pinMode(i, OUTPUT);
	// RTC module activation
	pinMode(rtcVCC,  OUTPUT);
	pinMode(rtcGND,  OUTPUT);
	pinMode(rtcSCLK, OUTPUT);
	pinMode(rtcIO,   OUTPUT);
	pinMode(rtcCE,   OUTPUT);
	digitalWrite(rtcVCC, HIGH);
	digitalWrite(rtcGND, LOW);
	// LCD initialization
	lcd.begin(16, 2);
	lcd.setCursor(4, 0);
	// Display hours:minutes:seconds
	displayTime();
	// Set & display relay based on EEPROM data
	lcd.setCursor(0, 1);
	lcd.print("1");
	relayAction(adr1ON, 1, relay1);
	lcd.setCursor(2, 1);
	lcd.print("2");
	relayAction(adr2ON, 3, relay1);
	lcd.setCursor(4, 1);
	lcd.print("3");
	relayAction(adr3ON, 5, relay1);
	lcd.setCursor(6, 1);
	lcd.print("4");
	relayAction(adr4ON, 7, relay1);
	lcd.setCursor(8, 1);
	lcd.print("5");
	relayAction(adr5ON, 9, relay1);
	lcd.setCursor(10, 1);
	lcd.print("6");
	relayAction(adr6ON, 11, relay1);
	lcd.setCursor(12, 1);
	lcd.print("7");
	relayAction(adr7ON, 13, relay1);
	lcd.setCursor(14, 1);
	lcd.print("8");
	relayAction(adr8ON, 15, relay1);
	// If the user presses the SELECT button, enter the settings menu
	if (read_LCD_buttons() == btnSELECT) {
		while (read_LCD_buttons() == btnSELECT);
		lcd.clear();
		lcd.setCursor(0, 0);
    lcd.write(byte(3));
		lcd.print("   TIME SETTING");
    lcd.write(byte(4));
		lcd.print("  CYCLE SETTING");
		while (read_LCD_buttons() == btnNONE);
		if (read_LCD_buttons() == btnUP) {
			while (read_LCD_buttons() == btnUP);
			setRTC();   // If the user presses the UP button, enter RTC settings menu
		else if (read_LCD_buttons() == btnDOWN) {
			while (read_LCD_buttons() == btnDOWN);
			setPin();   // If the user presses the DOWN button, enter PIN settings menu
void relayAction(int adrON, int pos, int pin) {
	myRTC.updateTime();
	int MinToday = (myRTC.hours * 60) + myRTC.minutes;
	int MinEprON = (EEPROM.read(adrON) * 60) + EEPROM.read(adrON + 1);
	lcd.setCursor(pos, 1);
	if (MinToday != MinEprON) {
		lcd.print("-");
		digitalWrite(pin, HIGH);
	else if (MinToday = MinEprON) {
		if (myRTC.seconds >= 3) {
			lcd.print("-");
		else {
			lcd.print("*");
			digitalWrite(pin, LOW);
// Setup function
void setRTC() {
	lcd.clear();
	lcd.print("TIME SETTING");
	lcd.clear();
	lcd.print("CURRENT ");
	setupShowValue2(myRTC.hours, myRTC.minutes, 0);
	lcd.print("NEW ");
	myRTC.updateTime();
	setupShowValue(myRTC.hours, myRTC.minutes, 1);
	setupChooseValueSetRTC(myRTC.hours, myRTC.minutes, 1);
	lcd.setCursor(0,0);
	lcd.print("SETTINGS SAVED   ");
	lcd.clear();
void setPin() {
	lcd.clear();
	delay(3000);
	lcd.clear();
	lcd.setCursor(3, 0);
  lcd.write(byte(0));
	lcd.print("CYCLE 1 :");
	eepromHour = EEPROM.read(adr1ON);
	eepromMin = EEPROM.read(adr1ON + 1);
	if (eepromHour >= 24) eepromHour = 0;
	if (eepromMin  >= 60) eepromMin  = 0;
  lcd.setCursor(13, 0);
  lcd.write(byte(2));
  lcd.setCursor(14, 0);
  lcd.write(byte(1));
	setupShowValue(eepromHour, eepromMin, 0);
	setupChooseValue(eepromHour, eepromMin, adr1ON, 0);
	lcd.clear();
  lcd.write(byte(0));
	lcd.print("CYCLE 2 :");
	eepromHour = EEPROM.read(adr2ON);
	eepromMin = EEPROM.read(adr2ON + 1);
  lcd.write(byte(2));
  lcd.write(byte(1));
	setupChooseValue(eepromHour, eepromMin, adr2ON, 0);
	lcd.clear();
  lcd.write(byte(0));
	lcd.print("CYCLE 3 :");
	eepromHour = EEPROM.read(adr3ON);
	eepromMin = EEPROM.read(adr3ON + 1);
  lcd.write(byte(2));
  lcd.write(byte(1));
	setupChooseValue(eepromHour, eepromMin, adr3ON, 0);
	lcd.clear();
  lcd.write(byte(0));
	lcd.print("CYCLE 4 :");
	eepromHour = EEPROM.read(adr4ON);
	eepromMin = EEPROM.read(adr4ON + 1);
  lcd.write(byte(2));
  lcd.write(byte(1));
	setupChooseValue(eepromHour, eepromMin, adr4ON, 0);
	lcd.clear();
  lcd.write(byte(0));
	lcd.print("CYCLE 5 :");
	eepromHour = EEPROM.read(adr5ON);
	eepromMin = EEPROM.read(adr5ON + 1);
  lcd.write(byte(2));
  lcd.write(byte(1));
	setupChooseValue(eepromHour, eepromMin, adr5ON, 0);
	lcd.clear();
  lcd.write(byte(0));
	lcd.print("CYCLE 6 :");
	eepromHour = EEPROM.read(adr6ON);
	eepromMin = EEPROM.read(adr6ON + 1);
  lcd.write(byte(2));
  lcd.write(byte(1));
	setupChooseValue(eepromHour, eepromMin, adr6ON, 0);
	lcd.clear();
  lcd.write(byte(0));
	lcd.print("CYCLE 7 :");
	eepromHour = EEPROM.read(adr7ON);
	eepromMin = EEPROM.read(adr7ON + 1);
  lcd.write(byte(2));
  lcd.write(byte(1));
	setupChooseValue(eepromHour, eepromMin, adr7ON, 0);
	lcd.clear();
  lcd.write(byte(0));
	lcd.print("CYCLE 8 :");
	eepromHour = EEPROM.read(adr8ON);
	eepromMin = EEPROM.read(adr8ON + 1);
  lcd.write(byte(2));
  lcd.write(byte(1));
	setupChooseValue(eepromHour, eepromMin, adr8ON, 0);
	lcd.clear();
void setupChooseValue(int HourNew, int MinNew, byte Address, byte Pos) {
	while (read_LCD_buttons() != btnSELECT) {
		if (read_LCD_buttons() == btnRIGHT) {
			if (HourNew < 23) {
				HourNew++;
		else if (read_LCD_buttons() == btnLEFT) {
			if (HourNew > 0) {
				HourNew--;
		else if (read_LCD_buttons() == btnUP) {
			if (MinNew < 59) {
				MinNew++;
			if (MinNew > 0) {
				MinNew--;
		setupShowValue(HourNew, MinNew, Pos);
		delay(150);
	while (read_LCD_buttons() != btnNONE);  // Wait until the button is released
	EEPROM.write(Address, HourNew);
	EEPROM.write(Address + 1, MinNew);
	delay(150);
void setupChooseValueSetRTC(int HourNew, int MinNew, byte Pos) {
			if (HourNew < 23) {
				HourNew++;
			if (HourNew > 0) {
				HourNew--;
			if (MinNew < 59) {
				MinNew++;
			if (MinNew > 0) {
				MinNew--;
		delay(150);
	myRTC.setDS1302Time(00, MinNew, HourNew, 6, 10, 1, 2014);
	delay(150);
void setupShowValue(int Hour, int Min, int Pos) {
	//lcd.setCursor(11, Pos);
  lcd.setCursor(11, 1);
	print2digits(Hour);
	lcd.print(":");
	print2digits(Min);
void setupShowValue2(int Hour, int Min, int Pos) {
	print2digits(Hour);
	lcd.print(":");
	print2digits(Min);
// LCD funtions
int read_LCD_buttons()
	adc_key_in = analogRead(0); // Read the value from the sensor
	if (adc_key_in > 1000) return btnNONE;
	if (adc_key_in < 50)   return btnRIGHT;
	if (adc_key_in < 150)  return btnUP;
	if (adc_key_in < 300)  return btnDOWN;
	if (adc_key_in < 500)  return btnLEFT;
	if (adc_key_in < 850)  return btnSELECT;
	return btnNONE; // When all others fail, return this.
void eeprom_write_int(int p_address, int p_value) {
	byte lowByte = ((p_value >> 0) & 0xFF);
	byte highByte = ((p_value >> 8) & 0xFF);
	EEPROM.write(p_address, lowByte);
	EEPROM.write(p_address + 1, highByte);
unsigned int eeprom_read_int(int p_address) {
	byte lowByte = EEPROM.read(p_address);
	byte highByte = EEPROM.read(p_address + 1);
	return ((lowByte << 0) & 0xFF) + ((highByte << 8) & 0xFF00);
void displayTime() {
	myRTC.updateTime();
	print2digits(myRTC.hours);
	lcd.print(":");
	print2digits(myRTC.minutes);
	lcd.print(":");
	print2digits(myRTC.seconds);
void print2digits(int number) {
	if (number >= 0 && number < 10)
		lcd.print('0');
	lcd.print(number, DEC);
I moved your topic to an appropriate forum category @chimi123 .
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Thank you for moving my topic to the appropriate category, and I appreciate the correction. I’ll make sure to choose the correct category in the future.
That is an assignment, not a test for equality
Thank you for the correction. I already tried using '==' but it still didn’t fix the issue.
Which Arduino? Which relay? How is the relay powered? How is the relay connected to the Arduino? What is the relay switching?
I'm using Arduino Mega 2560 pro, 5v 1 channel relay (low trigger), keypad shield, and a ds1302 rtc module. The connections are provided in the code.
Your logic is a bit flawed. You have one relay pin relay1 and you call your relayAction() function multiple times but always with that same pin. If one of your alarms matches, it will turn on, but the very next call will most likely result in turning it off, almost immediately. The next time through loop(), it will probably still match so it will turn back on, just to turn back off again.
can you try to fix my code? I'm already confused :rofl:
Using boolean control variables, the relayAction function could look like this for a 3 second relay on period. A state machine approach could also be used.
  static boolean timing = false;
  static boolean didRunThisMinute = false;
  static unsigned long startTime = 0;
  myRTC.updateTime();
  if (MinToday == MinEprON && didRunThisMinute == false) {
    didRunThisMinute = true;
    timing = true;
    startTime = millis();
    digitalWrite(pin, LOW);//turn on relay
    alreadyRunThisMinute = false;
  if (timing && millis() - startTime >= 3000)
    digitalWrite(pin, HIGH); //turn off relay
    timing = false;
The recommendation fixed a problem you have not yet observed.
Where did you find the code?
You can fix your own code. Since you want the buzzer to only be on for 3 seconds, just change your relayAction() function such that when you turn on the buzzer, you then wait 3 seconds and then turn it back off.
This will lead to another issue since you are only setting your alarms down to the minute. You will be able to test multiple times per minute which means you will get the same alarm being true multiple times. To fix that, you really don't need to test so often, just once per minute.
Hello, I just want to ask for a help, I want the relay to run for only 3 seconds then turn OFF later on. I can't implement that, can someone help me?
I am using a DS1302 RTC module, Arduino Uno, and a keypad shield
#include <EEPROM.h>
// Relay pin
#define relay1      0
// RTC module pins
#define rtcVCC      A5
#define rtcGND      A4
#define rtcSCLK     A3
#define rtcIO       A2
#define rtcCE       A1
// RTC object
// Keypad
#define btnRIGHT    0
#define btnUP       1
#define btnDOWN     2
#define btnLEFT     3
#define btnSELECT   4
#define btnNONE     5
// Mode
#define modeSETUP   1
#define adr1ON    2
#define adr2ON    6
#define adr3ON    10
#define adr4ON    14
#define adr5ON    18
#define adr6ON    22
#define adr7ON    26
#define adr8ON    30
// UP
// DOWN
int eepromMin = 0;
int eepromHour = 0;
int lcd_key     = 0;
int adc_key_in  = 0;
		pinMode(i, OUTPUT);
	lcd.begin(16, 2);
	displayTime();
	lcd.print("1");
	lcd.print("2");
	lcd.print("3");
	lcd.print("4");
	lcd.print("5");
	lcd.print("6");
	lcd.print("7");
	lcd.print("8");
		lcd.clear();
    lcd.write(byte(3));
    lcd.write(byte(4));
  myRTC.updateTime();
    timing = true;
    static boolean alreadyRunThisMinute = false;
    timing = false;
// Setup function
void setRTC() {
	lcd.clear();
	lcd.clear();
	lcd.print("NEW ");
	myRTC.updateTime();
	lcd.setCursor(0,0);
	lcd.clear();
void setPin() {
	lcd.clear();
	delay(3000);
	lcd.clear();
  lcd.write(byte(0));
  lcd.write(byte(2));
  lcd.write(byte(1));
	lcd.clear();
  lcd.write(byte(0));
  lcd.write(byte(2));
  lcd.write(byte(1));
	lcd.clear();
  lcd.write(byte(0));
  lcd.write(byte(2));
  lcd.write(byte(1));
	lcd.clear();
  lcd.write(byte(0));
  lcd.write(byte(2));
  lcd.write(byte(1));
	lcd.clear();
  lcd.write(byte(0));
  lcd.write(byte(2));
  lcd.write(byte(1));
	lcd.clear();
  lcd.write(byte(0));
  lcd.write(byte(2));
  lcd.write(byte(1));
	lcd.clear();
  lcd.write(byte(0));
  lcd.write(byte(2));
  lcd.write(byte(1));
	lcd.clear();
  lcd.write(byte(0));
  lcd.write(byte(2));
  lcd.write(byte(1));
	lcd.clear();
			if (HourNew < 23) {
				HourNew++;
			if (HourNew > 0) {
				HourNew--;
			if (MinNew < 59) {
				MinNew++;
			if (MinNew > 0) {
				MinNew--;
		delay(150);
	delay(150);
			if (HourNew < 23) {
				HourNew++;
			if (HourNew > 0) {
				HourNew--;
			if (MinNew < 59) {
				MinNew++;
			if (MinNew > 0) {
				MinNew--;
		delay(150);
	delay(150);
	print2digits(Hour);
	lcd.print(":");
	print2digits(Min);
	print2digits(Hour);
	lcd.print(":");
	print2digits(Min);
// LCD funtions
	myRTC.updateTime();
	lcd.print(":");
	lcd.print(":");
		lcd.print('0');
After your date/time happens, use a three-seconds timer...
unsigned long timer, interval = 3; // seconds
bool oneTime = 0; // flag to turn off only one time
byte relayPin = 13; // simulated relay pin
  pinMode(relayPin, OUTPUT);
  relayOn();
  relayOff();
void relayOn() {
  digitalWrite(relayPin, HIGH); // relay ON
  Serial.print(" ON at: ");
  Serial.println(millis());
void relayOff() {
  if (millis() - timer > interval * 1000) { // interval in ms
    if (!oneTime) {
      Serial.print("OFF at: ");
      digitalWrite(relayPin, LOW); // relay OFF
      oneTime = 1; // only one time
still did not fix sir
this is the link where I got the code:
Show your work.
In the previous posts, there were multiple suggestions to fix your code. The code you posted here still has the fundamental problem that you call relayAction() once for each of your alarms but within the function, it is trying to track time so each time you call it with a different alarm, it basically stomps over the previous alarm settings.
It would appear you need to take step back and learn some basic programming before taking on a project of this magnitude.
I have merged your cross-posts @chimi123.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
