Hello, I want the alarm to sound for 5 seconds but when im put delay on alarm function its not work. Where should i put delay func?
#include <Wire.h>
#include <LiquidCrystal_I2C.h> // library for LCD with I2C
#include <virtuabotixRTC.h>
#include <hd44780.h>
#include <DHT.h>
virtuabotixRTC myRTC(4, 3, 2);
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define DHTPIN 5
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
#include <EEPROM.h>
int h1;
int t;
const int btnChange = 8;
const int btnOK = 9;
const int btnMode = 10;
const int buzzer = 12;
int alarmHour = 12;
int alarmMinutes = 0;
boolean hourMode = 0;
boolean alarmOn = 1;
int M = 12;
int D = 31;
int Y = 2020;
int day = 7;
int h = 23;
int m = 59;
int addrH[] = {0, 1, 2, 3, 4};
int addrM[] = {5, 6, 7, 8, 9};
int addrActive[] = {10, 11, 12, 13, 14};
int mode = 1;
int submode = 1;
int slot = 0;
byte clockChar[] = {B00000, B01110, B10101, B10101, B10111, B10001, B01110, B00000};
byte alarmChar[] = {B00100, B01110, B01110, B01110, B11111, B00000, B00100, B00000};
byte dateChar[] = {B11111, B00000, B01100, B01010, B01010, B01100, B00000, B11111};
pinMode(btnChange, INPUT_PULLUP);
pinMode(btnOK, INPUT_PULLUP);
pinMode(btnMode, INPUT_PULLUP);
pinMode(buzzer, OUTPUT);
dht.begin();
lcd.init();
lcd.begin(16,2); // initialize the LCD
lcd.backlight(); // Turn on the blacklight
lcd.createChar(8, clockChar);
lcd.createChar(9, alarmChar);
lcd.createChar(10, dateChar);
/////////////////////////////////////////////////////////////////// void LOOP ///////////////////////////////////////////
h1 = dht.readHumidity();
t = dht.readTemperature();
if (digitalRead(btnMode) == LOW) {
mode++;
Serial.println("btnMode press");
if (mode == 4) {
mode = 1;
submode = 0;
lcd.clear();
delay(200);
if (mode == 1) {
clockDisplay();
Serial.println(mode);
// delay(200);
if (mode == 2) {
alarmMode();
// delay(200);
if (mode == 3) {
updateRTC();
// delay(200);
if (mode == 0) {
alarm();
EEPROM.write(addrActive[0], 0);
// delay(200);
for (int x = 0; x < 5; x++) {
if (EEPROM.read(addrActive[x]) == 1) {
Serial.print("alarm slot active: ");
Serial.println(x);
if ( myRTC.hours == EEPROM.read(addrH[x]) && myRTC.minutes == EEPROM.read(addrM[x])) {
EEPROM.write(addrActive[x], 0);
mode = 0;
void alarm() {
clockDisplay();
lcd.noBacklight();
digitalWrite(buzzer, HIGH);
delay(300);
lcd.backlight();
digitalWrite(buzzer, LOW);
delay(100);
/////////////////////////////////////////////////////////////////// CLOCK DISPLAY ///////////////////////////////////////////
void clockDisplay() {
myRTC.updateTime();
// lcd.clear();
lcd.setCursor(0, 0);
lcd.print(t);
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(0, 1);
lcd.print(h1);
lcd.print("%");
lcd.setCursor(3, 1);
switch (myRTC.month) {
case 1: lcd.print("Ock"); break;
case 2: lcd.print("Sbt"); break;
case 3: lcd.print("Mar"); break;
case 4: lcd.print("Nis"); break;
case 5: lcd.print("May"); break;
case 6: lcd.print("Haz"); break;
case 7: lcd.print("Tem"); break;
case 8: lcd.print("Agu"); break;
case 9: lcd.print("Eyl"); break;
case 10: lcd.print("Eki"); break;
case 11: lcd.print("Kas"); break;
case 12: lcd.print("Ara"); break;
if (myRTC.dayofmonth < 10) {
lcd.print(" ");
lcd.print(myRTC.dayofmonth);
else{
lcd.print(",");
lcd.print(myRTC.year);
lcd.setCursor(13, 1);
switch (myRTC.dayofweek) {
case 1: lcd.print("Paz"); break;
case 2: lcd.print("Pzt"); break;
case 3: lcd.print("Sal"); break;
case 4: lcd.print("Car"); break;
case 5: lcd.print("Per"); break;
case 6: lcd.print("Cum"); break;
case 7: lcd.print("Cts"); break;
lcd.setCursor(5, 0);
if ((myRTC.hours > 12 && myRTC.hours < 22) || (myRTC.hours > 0 && myRTC.hours < 10)) {
lcd.print("0");
if (myRTC.hours == 0) {
lcd.print("12");
else if (myRTC.hours <= 12) {
lcd.print(myRTC.hours);
else {
lcd.print(myRTC.hours - 12);
lcd.print(":");
if (myRTC.minutes < 10) {
lcd.print("0");
lcd.print(myRTC.minutes);
lcd.print(":");
if (myRTC.seconds < 10) {
lcd.print("0");
lcd.print(myRTC.seconds);
lcd.print(" ");
if (myRTC.hours < 12) {
lcd.print("OO");
else {
lcd.print("OS");
/////////////////////////////////////////////////////////////////// ALARM FUNCTION ///////////////////////////////////////////
void alarmMode() {
if (submode == 0) {
lcd.write(1);
lcd.setCursor(2, 0);
lcd.print("Sec:");
if (digitalRead(btnChange) == LOW) {
slot++;
if (slot > 4 ) {
slot = 0;
delay(200);
lcd.setCursor(10, 0);
lcd.print("Slot#");
lcd.print(slot + 1);
if (EEPROM.read(addrH[slot]) > 23) {
EEPROM.write(addrH[slot], 0);
if (EEPROM.read(addrM[slot]) > 59) {
EEPROM.write(addrM[slot], 0);
if (EEPROM.read(addrActive[slot]) > 1) {
EEPROM.write(addrActive[slot], 0);
if ((EEPROM.read(addrH[slot]) > 12 && EEPROM.read(addrH[slot]) < 22) || (EEPROM.read(addrH[slot]) > 0 && EEPROM.read(addrH[slot]) < 10)) {
lcd.print("0");
if (EEPROM.read(addrH[slot]) == 0) {
lcd.print("12");
alarmHour = 12;
else if (EEPROM.read(addrH[slot]) <= 12) {
lcd.print(EEPROM.read(addrH[slot]));
alarmHour = EEPROM.read(addrH[slot]);
else {
lcd.print(EEPROM.read(addrH[slot]) - 12);
alarmHour = EEPROM.read(addrH[slot]) - 12;
lcd.print(":");
if (EEPROM.read(addrM[slot]) < 10) {
lcd.print("0");
lcd.print(EEPROM.read(addrM[slot]));
alarmMinutes = EEPROM.read(addrM[slot]);
lcd.print(" ");
if (EEPROM.read(addrH[slot]) < 12) {
lcd.print("OO");
hourMode = 0;
else {
lcd.print("OS");
hourMode = 1;
lcd.print(" ");
if (EEPROM.read(addrActive[slot]) == 1) {
lcd.print("Acik ");
else {
lcd.print("Kapali");
else {
lcd.write(1);
lcd.print("Ayarla|");
lcd.print("Alarm ||");
lcd.setCursor(9, 1);
if (alarmHour < 10) {
lcd.print("0");
lcd.setCursor(10, 1);
lcd.print(alarmHour);
lcd.setCursor(11, 1);
lcd.print(":");
lcd.setCursor(12, 1);
if (alarmMinutes < 10) {
lcd.print("0");
lcd.print(alarmMinutes);
if (hourMode == 0) {
lcd.print("OO");
else {
lcd.print("OS");
// lcd.print(alarmMinutes);
if (digitalRead(btnOK) == LOW) {
submode++;
if (submode > 4) {
submode = 0;
delay(200);
lcd.clear();
if (submode == 1) {
lcd.setCursor(9, 0);
lcd.write(1);
lcd.write(1);
alarmHour++;
if (alarmHour > 12) {
alarmHour = 1;
if (submode == 2) {
lcd.setCursor(12, 0);
lcd.write(1);
lcd.write(1);
alarmMinutes++;
if (alarmMinutes >= 60) {
alarmMinutes = 0;
if (submode == 3) {
lcd.setCursor(14, 0);
lcd.write(1);
lcd.write(1);
hourMode = !hourMode;
while (submode == 4) {
lcd.print("Alarm Aktif?");
lcd.print("Slot #");
lcd.print(" ");
if(alarmOn==1){
lcd.print("Acik ");
else{
alarmOn = !alarmOn;
delay(200);
if (digitalRead(btnOK) == LOW && alarmOn == 1) {
lcd.clear();
lcd.print("Ayarlaniyor.");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
if (hourMode == 1 && alarmHour != 12) {
EEPROM.write(addrH[slot], alarmHour + 12);
else if (hourMode == 0 && alarmHour == 12) {
else {
EEPROM.write(addrH[slot], alarmHour);
EEPROM.write(addrM[slot], alarmMinutes);
EEPROM.write(addrActive[slot], 1);
submode = 0;
mode = 1;
lcd.clear();
if (digitalRead(btnOK) == LOW && alarmOn == 0) {
lcd.clear();
lcd.print("Alarm Slot#");
lcd.print(" OFF ");
submode = 0;
mode = 1;
delay(600);
delay(2000);
lcd.clear();
/////////////////////////////////////////////////////////////////// SETTING DATE & TIME FUNCTION ///////////////////////////////////////////
void updateRTC() {
lcd.write(2);
submode++;
if (submode > 7) {
submode = 0;
delay(200);
lcd.clear();
if (submode == 0) {
lcd.print(" Tarih/Zaman");
lcd.print("icin kirmizi tus");
if (submode == 1) {
lcd.print("Ay Ayarla");
lcd.print("--> ");
M++;
if (M == 13) {
M = 1;
delay(200);
switch (M) {
case 1: lcd.print("Ocak ");
case 2: lcd.print("Subat ");
case 3: lcd.print("Mart ");
case 4: lcd.print("Nisan ");
case 5: lcd.print("Mayis ");
case 6: lcd.print("Haziran ");
case 7: lcd.print("Temmuz ");
case 8: lcd.print("Agustos ");
case 9: lcd.print("Eylul ");
case 10: lcd.print("Ekim ");
case 11: lcd.print("Kasim ");
case 12: lcd.print("Aralik ");
if (submode == 2) {
lcd.print("Gun Ayarla");
lcd.print("--> ");
D++;
if (D == 32) {
D = 1;
delay(200);
lcd.print(D);
lcd.print(" ");
if (submode == 3) {
lcd.print("Yil Ayarla");
lcd.print("--> ");
Y++;
if (Y == 2099) {
Y = 2000;
delay(200);
lcd.print(Y);
if (submode == 4) {
lcd.print("Haftanin hangi gunu?");
lcd.print("--> ");
day++;
if (day == 8) {
day = 1;
delay(200);
switch (day) {
case 1: lcd.print("Pazar ");
case 2: lcd.print("Pazartesi ");
case 3: lcd.print("Sali ");
case 4: lcd.print("Carsamba ");
case 5: lcd.print("Persembe ");
case 6: lcd.print("Cuma ");
case 7: lcd.print("Cumartesi ");
if (submode == 5) {
lcd.print("Saat ayarla");
lcd.print("--> ");
h++;
if (h == 24) {
h = 0;
delay(200);
if (h > 12) {
lcd.print(h - 12);
lcd.print(" ");
else if (h == 0) {
lcd.print("12");
lcd.print(" ");
else {
lcd.print(h);
lcd.print(" ");
if (h >= 12) {
lcd.print("OS");
else {
lcd.print("OO");
if (submode == 6) {
lcd.print("Dakika Ayarla");
lcd.print("--> ");
m++;
if (m == 60) {
m = 0;
delay(200);
lcd.print(m);
lcd.print(" ");
if (submode == 7) {
lcd.print("Tarih & Zaman");
lcd.print("Guncelleniyor");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
delay(200);
lcd.print(".");
myRTC.setDS1302Time(00, m, h, day, D, M, Y);
delay(200);
lcd.clear();
mode = 1;
