set time on LED with button
I am trying to glow LED with push button using below code but LED is glowing without pressing push button.
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
hd44780_I2Cexp lcd;
const int LCD_COLS = 16;
const int LCD_ROWS = 2;
int pushButton = 3;
int pinLED = 8;
int stateLED = 0;
int stateButton;
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
lcd.begin(LCD_COLS, LCD_ROWS);
lcd.backlight();
lcd.setBacklight(HIGH);
lcd.setCursor(0, 0);
pinMode(pushButton, INPUT_PULLUP); // set up as Relay button
pinMode(pinLED, OUTPUT); // set up LED
stateButton = digitalRead(pushButton); // read pushbutton state at analog input
if (stateButton == 1) {
digitalWrite(pinLED, 1);
lcd.setCursor(0, 1);
lcd.print("HIGH ");
lcd.blink();
digitalWrite(pinLED, 0);
lcd.print("LOW ");
lcd.blink();
When you use INPUT_PULLUP and the button is wired correctly (between pin and GND), the logic is reversed. So a 1 (or HIGH) indicates not-pressed.
Please read https://forum.arduino.cc/index.php?topic=148850.0 and pay special attention to point #7 about posting code.
You have necro'd and hijacked a 6 years old thread. Please contact a moderator and request that it be split off to a new topic. Please don't do this again.
@pankajsharma200
TOPIC SPLIT
PLEASE DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
