The code of my transmitter looks like the following:
if (!radio.begin()) {
while (1);
radio.setPALevel(RF24_PA_HIGH);
radio.setDataRate(RF24_250KBPS);
radio.setRetries(100, 20);
radio.startListening();
Serial.println("ok");
If i add radio.setChannel(1) on both receiver and transmitter, the transmission does not work anymore - it tries to send messages without success.
The code looks like the following on both receiver and trasnmitter:
while (1);
radio.setChannel(1)
b707
April 11, 2025, 6:32pm
2
Have you managed to achieve communication on any other channel number?
I’ve tested multiple numbers, also high numbers like 124, nothing worked
TMRh20
April 12, 2025, 8:25am
4
What kind of radios are you using? I'm going to guess the PA+LNA versions with antennas?
Have you tried at a higher data rate like RF24_2MBPS and lower PALevel like RF24_PA_MIN ?
You are using an invalid retry value, the max is 15. Try a balanced number like setRetries(5,5).
I'm using the nRF24L01+, in this settings https://www.youtube.com/shorts/Dy5WsPUHh50 (without the big/long antenna)
I've tried with lower data rate (250kbps).
Why should i try with higher data rate? I mean, shouldn't channel work with any data rate? In the docs I don't find anything suggesting that the channel depends on the data rate.
Same for PALevel.
TMRh20
April 13, 2025, 3:24pm
6
I develop and maintain the RF24 library. I suspect power supply issues. I am concerned also if there are any bugs in the library. That is why I ask.
system
Closed
October 10, 2025, 3:25pm
7
