setColor error
#include <dht.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
dht DHT;
#define DHT11_PIN 7
const int redPin = 10;
const int greenPin = 9;
const int bluePin = 8;
  lcd.begin(16, 2);
  if (DHT.temperature <0) {
    setColor(0, 0, 255);
    int chk = DHT.read11(DHT11_PIN);
  lcd.setCursor(0,0);
  lcd.print("Temp: ");
  lcd.print(DHT.temperature);
  lcd.print((char)223);
  lcd.print("C");
  lcd.setCursor(0,1);
  lcd.print("Humidity: ");
  lcd.print(DHT.humidity);
  lcd.print("%");
That’s the code I’m using, and I’m getting this error.
‘setColor’ was not declared in this scope
The error message doesn’t make sense to me, since this Adafruit code I’m using that also doesn’t declare what setColor is doesn’t get the error.
Adafruit Arduino - Lesson 3. RGB LED
int redPin = 11;
int greenPin = 10;
int bluePin = 9;
//uncomment this line if using a Common Anode LED
//#define COMMON_ANODE
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  setColor(255, 0, 0);  // red
  setColor(0, 255, 0);  // green
  setColor(0, 0, 255);  // blue
  setColor(255, 255, 0);  // yellow
  setColor(80, 0, 80);  // purple
  setColor(0, 255, 255);  // aqua
void setColor(int red, int green, int blue)
  #ifdef COMMON_ANODE
    red = 255 - red;
    green = 255 - green;
    blue = 255 - blue;
  #endif
  analogWrite(redPin, red);
  analogWrite(greenPin, green);
  analogWrite(bluePin, blue);
The second sketch has a function called setColor; the first does not.
