SetControllerDirection in a Loop?
Hello and Thank you for reading this.
Is there any reason I cannot change the controller direction in a PID loop??? I want output if the Input is ABOVE or BELOW the setpoint. (IE a thermastat that heats and cools)
 * PID Basic Example
 * Reading analog input 0 to control analog PWM output 3
#include <PID_v1.h>
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
  //initialize the variables we're linked to
  Input = analogRead(0);
  Setpoint = 100;
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
if(SetPoint>InpuT){SetControllerDirection(DIRECT);}
if(Input>SetPoint){SetControllerDirection(REVERSE);}
  myPID.Compute();
  analogWrite(3,Output);
Can I be clear ? Do you want a cooler turned on if the output is above the setpoint and a heater turned on if the output is below the setpoint ? If so, then can you use 2 PIDs ?
Hello:
Is there any reason I cannot change controller direction in a PID loop? I bascially want a thermastat that will heat up to the setpoint and then cool back down…
 * PID Basic Example
#include <PID_v1.h>
  Setpoint = 100;
  //turn the PID on
if(Setpoint>=Input){SetControllerDirection(Direct);}
if(Input>Setpoint){SetCtonrollerDirection(Reverse);}
  myPID.Compute();
[code/]
@house231, do not cross-post. Threads merged.
UKHeliBob: If so, then can you use 2 PIDs ?
Split range output is also a good choice.
Sorry about the cross post, it was not intentional, the server has been on the fritz for half a day.
Yes I want a cooler turned on if the output is above the setpoint and a heater turned on if the output is below the setpoint. The switching of the SetControllerDirect does seem to work but I dont know if that is screwing things up somehow. I am not sure how to code for a split range or two separate PID
