'setLockState' was not declared in this scope???
Nous sommes partis d'un sketch :
qui, en gros, consiste à entrer un code sur un keypad et utiliser ensuite un senseur digital pour ouvrir un solenoid.
Nous voulons le modifier pour pouvoir entrer un code sur le keypad, et à la place du senseur digital, utiliser un touch sensor. Toutefois, lors de la modification du sketch, nous nous retrouvons avec l'erreur: "setLockState' was not declared in this scope".
Nous en sommes à nos premiers pas dans le monde de l'Arduino, peut-être que l'erreur que nous faisons vous sautera au yeux :wink:
ci-joint: sketch initial ( bioboxmetric.ino ) et sketch modifié (biobox)
bioboxmetric.ino (4.59 KB)
biobox.ino (3.25 KB)
  Biometric Box Sketch for the optical Fingerprint sensor
  This sketch implements a two-level security scheme requiring the
  user to enter a passcode via the keypad before scanning a fingerprint
  for access.
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Bill Earl for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Keypad.h>
#include <SoftwareSerial.h>
// Define the states for the lock state machine
#define LOCKED 2
#define PASSWORD_OK 1
#define UNLOCKED 0
// State Variables:   Initialize to the locked state
int LockState = LOCKED;
int ButtonState = 0;
int LedpinState=0;
int SolenoidPinState=0;
int position = 0;
int LedPin = 10;
int SolenoidPin = 11;
int Button = 13;
// Define your password key sequence here
char* secretCode = "1423";
// Keypad key matrix:
const byte rows= 4; //number of rows on the keypad
const byte cols= 4; //number of columns on the keypad
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keys[rows][cols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
//Code that shows the the keypad connections to the arduino terminals
byte rowPins[rows] = {9,8,7,6}; //Rows 0 to 3
byte colPins[cols]= {5,4,3,2}; //Columns 0 to 3
//initializes an instance of the Keypad class
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, rows, cols);
// More pin definitions:
   pinMode(LedPin, OUTPUT);
   pinMode(SolenoidPin, OUTPUT);
   pinMode(Button, INPUT);
   // Run the state machine:
   // Locked State - Monitor keypad for valid Password code entry
   if (LockState == LOCKED)
      char key = keypad.getKey();
      if (key == '*' || key == '#')
         position = 0;
         setLockState(LOCKED);
      if (key != 0)
         if (key == secretCode[position])  // Valid key in Password sequence
            Serial.print("Matched ");
            Serial.print(key);
            Serial.print("-at-");
            Serial.println(position);
            position ++;
         else  // Invalid key - start all over again
            Serial.println("Invalid Code!");
            position = 0;
      if (position == 4)  // Password successfully entered - advance state
         setLockState(PASSWORD_OK);
         position = 0;
         digitalWrite(SolenoidPin,HIGH);
      delay(100);
   // PASSWORD_OK state - Now wait for a valid fingerprint reading
else if (LockState == PASSWORD_OK)
      if (digitalRead(Button)==HIGH);
         setLockState(UNLOCKED);
         digitalWrite(SolenoidPin, LOW);//  avance à UNLOCKED
     digitalWrite(LedPin, HIGH);//allume la led
{      setLockState (LOCKED);
digitalWrite(SolenoidPin, HIGH);// Time-out - go back to the locked state.
  digitalWrite(LedPin, LOW);
Où se trouve fonction "setLockState"?
void setLockState(int state)
   LockState = state;
   if (state == LOCKED)
      Serial.println("Locked!");
   else if (state == PASSWORD_OK)
      Serial.println("PASSWORD_OK!");
   else if (state == UNLOCKED)
      Serial.println("Unlocked!");
Merci énormément AWOL pour cette remarque, ce que j'ai compris, c'est qu'étant déjà défini plus tard, je ne devais pas les redéfinir à chaque fois...
j'ai modifié et le tout compile. reste à voir si la circuiterie est bien faite;))
suite......comme le but est d'entrer un code dans un keypad, et ensuite de toucher un senseur avec la main pour valider le tout et faire ouvrir un aimant solenoid... J'ai tenté de simplifier le tout au maximum, ça compile (plus de .setLockState"was not declared in this scope") mais le tout ne fonctionne pas.
Je tente de comprendre la logique mais après plusieurs heures de recherche, quelque chose m'échappe assurément. :slight_smile: le résultat de ma tentative d'adaptation est en pièce jointe
Si quelqu'un peut m'orienter un peu, j'apprécierais beaucoup.....merci
bioboxessai.ino (2.41 KB)
#include <Keypad.h>
#define LOCKED 2
#define UNLOCKED 0
int position = 0;
int ButtonState;
int LedpinState;
int SolenoidPinState;
int LedPin = 10;
int Button = 13;
char* secretCode = "1234";
  LockState==LOCKED;
         position = 0;
      if (key != 0)
         if (key == secretCode[position]) //Valid code
            position = 0;
      delay(100);
   // PASSWORD_OK state - Now wait for a sensor reading
      if (digitalRead(Button)==LOW);
     { setLockState(UNLOCKED);
 //set the state and time of the state change
   LockState = state;
