this is the lib its using /*
Joystick.h
Copyright (c) 2015, Matthew Heironimus
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#ifndef JOYSTICK_h
#define JOYSTICK_h
#include “HID.h”
#if ARDUINO < 10606
#error The Joystick library requires Arduino IDE 1.6.6 or greater. Please update your IDE.
#endif
#if !defined(USBCON)
#error The Joystick library can only be used with a USB MCU (e.g. Arduino Leonardo, Arduino Micro, etc.).
#endif
#if !defined(_USING_HID)
#warning “Using legacy HID core (non pluggable)”
#else
// Joystick (Gamepad)
class Joystick_
private:
bool autoSendState;
int8_t xAxis;
int8_t yAxis;
int8_t zAxis;
int16_t xAxisRotation;
int16_t yAxisRotation;
int16_t zAxisRotation;
uint32_t buttons;
uint8_t throttle;
uint8_t rudder;
int16_t hatSwitch[2];
public:
Joystick_();
void begin(bool initAutoSendState = true);
void end();
void setXAxis(int8_t value);
void setYAxis(int8_t value);
void setZAxis(int8_t value);
void setXAxisRotation(int16_t value);
void setYAxisRotation(int16_t value);
void setZAxisRotation(int16_t value);
void setButton(uint8_t button, uint8_t value);
void pressButton(uint8_t button);
void releaseButton(uint8_t button);
void setThrottle(uint8_t value);
void setRudder(uint8_t value);
void setHatSwitch(int8_t hatSwitch, int16_t value);
void sendState();
extern Joystick_ Joystick;
#endif
#endif
