setting a byte variable to "zero"?
I have a byte variable called "uint8_t data2[47]" which I would like to set to "0" (i.e: just contain the value zero).
Since I'm new working with bytes, does anyone have any suggestions on how to do this?
data2[47]=0;
Just don't put any quotes around it or it will assume you want the character "0"
You have a byte array called data2 which you would like to make element 47 equal to zero:
data2[47] = 0;
coding1227:
Do you mean the whole array?
memset (data2, 0, sizeof data2);
data2[47]=0;
Nice job of writing beyond the end of the array. 8)
Yeah ok.
I was assuming that data2[47] was the actual member of an array (of unknown size) that she wants to set to zero.
Reading it again it looks like that’s the whole array. :stuck_out_tongue:
Thank you so much, guys! This was really helpful & instructive. BTW, Nick, your trick worked flawlessly :slight_smile:
Nick’s code isn’t a “trick”. It’s based on his knowledge of the standard C library. There are a bunch of functions there waiting for you to use them. Get familiar with the Standard C library so you don’t reinvent the wheel.
