Setting a DS3231 RTC via Serial
I am developing a Data logger with the Nano board and 4 Channel AI module from Circutar. Nanoshield
For time reference I am using a DS3231 module. Since code space is a bit tight I am unable to add code for setting the RTC time & date using three push buttons.
But the whole unit has access to Serial port which I am using for downloading the CSV file from the SD card. I think there is a method to use the Time library and get teh PC time. Unable to lay my hands on that link ….
Also is there any other method to do this ?
search term: Arduino set RTC compiler time
one of many threads on this subject
Ardubit:
Since code space is a bit tight ..............Also is there any other method to do this ?
You might consider whether you need to do this at all. DS3231 is pretty accurate - to a point that may be beyond what your real needs are.
@Geek Emeritus
thanks ... exactly the term i was looking for. Will take on from here.
Nick_Pyner:
:wink: Yes yes … the accuracy that the DS3231 delivers is pretty good. My requirement is only for the first time and later to correct any drift after long time . So even though its once in a bluemoon, i need to provide the facility to the user.
Searched and located a sample code that could do what I want …
But when I try to compile for a Nano, i get an error ‘DS3231 clock’ redeclared as different kind of symbol’
If try renaming clock to myClock, then I get a error " setSyncProvider() not defined in this scope"
Whats happening ? ( I am sure C++ experts will be tired with this… sorry)
#include <Wire.h>         //http://arduino.cc/en/Reference/Wire (included with Arduino IDE)
#include <DS3231.h>       //Jarzebski DS3231
#include <Time.h>         //http://www.arduino.cc/playground/Code/Time
DS3231 clock;
RTCDateTime dt;
uint32_t syncProvider()
  dt = clock.getDateTime();
  return dt.unixtime;
void setup(void)
  Wire.begin();
  clock.begin();
  setSyncProvider(syncProvider);   // the function to get the time from the RTC
  if (timeStatus() != timeSet)
    Serial.println("Unable to sync with the RTC");
    Serial.println("RTC has set the system time");
void loop(void)
  timeDateDisplay();
void timeDateDisplay(void)
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(' ');
  Serial.print(month());
  Serial.print("/");
  Serial.print(day());
  Serial.print("/");
  Serial.print(year());
  Serial.print("Unix Time ");
  Serial.println(now());
void printDigits(int digits)
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(':');
  if (digits < 10)
    Serial.print('0');
  Serial.print(digits);
