Setting an Array conditionally
I'm stuck and could use some help.
I'm attempting to read a toggle switch's (message_switch) position, and based on whether it is HIGH or LOW, to send a different message out on a particular pin. The message being sent is stored as an array in const char beacon_call_1 and beacon_call_2.
I have the switch set up correctly and verify that the Arduino is reading the High/Low correctly.
My trouble is when I try and set a variable equal to the array, I get an expected primary-expression token error. I believe that the issue I'm running into is because I'm trying to pass different types, but I can't remember how to properly set it up...
To say this in a different way: depending on the value of the switch, I want to make the variable my_message set equal to a different message. On = beacon_call_1 and Off = beacon_call_2.
beacon_call[] will then be set equal to my_message.
Thank you for any help.
#include <Morse.h>
#define blue 7    // Blue Led Pin
#define green 8   // Green LED Pin
#define red 9     // Red Led Pin
const int on_off_switch_pin = 4;
const int message_switch = 5;
const int mode = 1;   // Mode 0 = Beacon 1 = Foxhunt
char my_message ;
const char beacon_call_1[] = "MY DOG ATE MY HOMEWORK";  // Message to Send
const char beacon_call_2[] = "TEST";  // Message to Send
const int key_speed = 20;  // CW send speed
int interval = 2;     // Timer interval in seconds - This is the amount of time between the end of the transmission and the repeat of it.
int repeat = 1; // Repeat message time in seconds - must be a minimum of 1
const int beep_pin = 11; // Pin for CW tone
int key_pin = 12;  // Pin for PTT/Rig Key
long end_time;  // Foxhunt timing
char c;  // Character to send
bool first_pass = true;  // Flag to tell us this is the first time through
unsigned long offset = 0L;  // Timer value
Morse morse(beep_pin, key_speed, 1); // Set up the Morse Library for use
int msg_length;  // variable to hold the size of the message text array
// Timer function - returns the time in seconds since last Timer Reset
unsigned long Timer()
  return (millis()- offset)/1000;  // return time in seconds
// Timer Reset function
void TimerReset(unsigned long val = 0L)
  offset = millis() - val;
  pinMode(on_off_switch_pin, INPUT);
  pinMode(message_switch, INPUT);
  digitalRead(message_switch);
  if(message_switch == HIGH){
    my_message = beacon_call_1[];
  else{
    my_message = beacon_call_2[];
  char beacon_call[] = my_message;
  pinMode(key_pin, OUTPUT);           // set PTT/Key pin to output
  pinMode(red, OUTPUT);  // Set up the LED pins for output
  pinMode(green, OUTPUT);
  pinMode(blue, OUTPUT);
  digitalWrite(key_pin,LOW); // Turn off the PTT/Key relay
  ledOff();  // Turn off the LED
  delay(5000);  // Wait 5 seconds
  TimerReset();  // Reset the Timer to zero
  ledGreen();  // Turn on the Green LED to indicate Beacon/Keyer ready
  msg_length =(sizeof(beacon_call))-1;  // Calculate the size of the message text array
}  // End Setup Loop
void loop()  // Main Program Loop
  if(digitalRead(on_off_switch_pin) == HIGH){
  if (Timer() > interval | first_pass)  // Send if the Timer has expired or if this is the first time through
    first_pass = false;  // Set the flag to off
    if (mode == 0)  // Set the Key mode and LED for Beacon or Foxhunt
      // Set Beacon Mode
      Morse(key_pin, key_speed, 0);    // Set up to key the Relay
      ledBlue();  // Turn on the Blue LED to indicate Beacon Message Transmitting
      // Set Foxhunt Mode
      Morse(beep_pin, key_speed, 1);  // Set up to send modulated CW
      ledRed();  // Turn on the Red LED to indicate Foxhunt Message Transmitting
      digitalWrite(key_pin, HIGH);  // Key the PTT
    end_time = Timer() + repeat;  // If we're in Foxhunt mode, repeat the message until the repeat time has expired
    while(Timer() < end_time)  // Check to make sure repeat timer has not expired (Foxhunt Mode)
      for (int x = 0; x < msg_length; x++)  // Send the message in the beacon_call character array one character at a time
        c = beacon_call[x];  // Get the next letter to send
        morse.send(c);  // Send it in CW
      if (mode == 1)  // Send a space if we're in Foxhunt mode to separate messages
        morse.send(char(32));
        end_time = Timer()-1;
    digitalWrite(key_pin, LOW);  // Make sure the PTT is off
    ledGreen();  // Turn the LED Green to indicate Ready condition
    TimerReset();  // Reset the timer to restart the Interval between messages
else{};
// LED Off function
void ledOff()
  digitalWrite(red, LOW);  // Set all RBG LED pins High (Off)
  digitalWrite(green, LOW);
  digitalWrite(blue, LOW);
// RED LED ON function
void ledRed()
  digitalWrite(red, HIGH);  // Turn on the RGB Red LED On
// Green LED ON function
void ledGreen()
  digitalWrite(green, HIGH);  // Turn on the RGB Green LED On
// Blue LED ON function
void ledBlue()
  digitalWrite(blue, HIGH);  // Turn on the RGB Blue LED On
You declared my_message as a char, not an array of char
aarg - How do I define it as an array without specifying the size of the array? I have two different messages that will be passed to the array, both of different sizes.
You could probably make beacon_call a pointer to char:
char *beacon_call;
and then assign it like:
    if( digitalRead(message_switch) == HIGH )
        beacon_call = beacon_call_1;
        beacon_call = beacon_call_2;
When you send it, do something like:
                int x=0;
                while( *(beacon_call+x) )
                    morse.send( *(beacon_call+x) );  // Send it in CW
                    x++;
                }//while
this will send characters until the NULL termination.
Blackfin, that worked perfectly! I just hooked it up into my circuit and it is behaving exactly as I desired. THANK YOU! Now I need to learn more about these pointers and how they work. Time to do some reading!
This is a good introduction
https://www.cs.bu.edu/teaching/cpp/string/array-vs-ptr/
