Hi I am trying to get the colors of ws28128b led strip to change color based on how long I hold a button. I am using an Elegoo Uno R3 as the board. I can get the first color to work and turn off but the second color does nothing. When I verify the code I have no errors.
This is the code I have.
float pressLength_milliSeconds = 0;
int optionOne_milliSeconds = 100;
int optionTwo_milliSeconds = 500;
int optionThree_milliSeconds = 1000;
int buttonPin = 3;
#include <FastLED.h>
#define NUM_LEDS_PER_STRIP 180
CRGB leds[NUM_LEDS_PER_STRIP];
void setup(){
pinMode(buttonPin, INPUT_PULLUP);
FastLED.addLeds<NEOPIXEL, 2>(leds, NUM_LEDS_PER_STRIP);
} // close setup
while (digitalRead(buttonPin) == LOW ){
delay(100);
pressLength_milliSeconds = pressLength_milliSeconds + 100;
Serial.print("ms = ");
Serial.println(pressLength_milliSeconds);
if (pressLength_milliSeconds >= optionTwo_milliSeconds){
for(int i = 0; i < NUM_LEDS_PER_STRIP; i++) {
leds[i] = CRGB::Black;
FastLED.show();
delay(1);
else if(pressLength_milliSeconds >= optionOne_milliSeconds){
for(int i = NUM_LEDS_PER_STRIP-1; i >= 0; i--) {
leds[i] = CRGB(0, 0, 225);;
FastLED.show();
delay(1);
else if(pressLength_milliSeconds >= optionThree_milliSeconds){
leds[i] = CRGB(0, 225, 0);;
FastLED.show();
delay(1);
How could you tell anything about what that code was supposed to do with the indentation all over the place like that?
Try checking for the longest press length first.
Then the next longest.
Then the shortest.
Rather than checking for the second longest first, then the shortest, and only then checking for the longest. If pressLength is > 1000 but you check for > 500 first, you'll never get to the else if > 1000 part.
Thank You! It works now. I fixed the indentations it helped a lot.
alto777
February 24, 2025, 5:01am
4
Please post your prett(ier) code that works now.
a7
Code tags are three back ticks (```) on their own line (before and after the code). You did not do that for the opening code tag which was interpreted as a code formatting instruction. As a result float pressLength_milliSeconds = 0; did not show.
I've fixed it for you.
Two common uses of opening code tag with optional formatting
```cpp for cpp files; it's the default behaviour.
```text for e.g. output of the serial monitor or error messages.
Here is the fixed code:
int optionFour_milliSeconds = 1000;
int optionThree_milliSeconds = 1500;
int T = 20;
int buttonPin = 3;
#include "DHT.h"
#define NUM_LEDS_PER_STRIP 150
#define DHT11_PIN 4
DHT dht11(DHT11_PIN, DHT11);
void setup(){
delay(3000);
dht11.begin(); // initialize the sensor
} // close setup
delay(100);
leds[i] = CRGB(0, 0, 0);;
FastLED.show();
delay(T);
else if(pressLength_milliSeconds >= optionFour_milliSeconds){
leds[i] = CRGB(255, 0, 0);;
FastLED.show();
delay(T);
else if(pressLength_milliSeconds >= optionTwo_milliSeconds){
FastLED.show();
delay(T);
FastLED.show();
delay(T);
// read humidity
float humi = dht11.readHumidity();
// read temperature as Celsius
float tempC = dht11.readTemperature();
// read temperature as Fahrenheit
float tempF = dht11.readTemperature(true);
// check if any reads failed
if (isnan(humi) || isnan(tempC) || isnan(tempF)) {
Serial.println("Failed to read from DHT11 sensor!");
Serial.print("DHT11# Humidity: ");
Serial.print(humi);
Serial.print("%");
Serial.print(" | ");
Serial.print("Temperature: ");
Serial.print(tempC);
Serial.print("°C ~ ");
Serial.print(tempF);
Serial.println("°F");
blh64
February 25, 2025, 8:25pm
7
arduinorocks15:
FastLED.show();
You don't need to set the same led to the same value twice - once is enough.
You also don't need double semi-colons at the ends of many of your lines.
system
Closed
August 24, 2025, 8:26pm
8
