Setting Infrared Value to variable to control servos
Hi Everyone,
I have been using the code below from Ken Shirriff’s blog for an infrared sensor and was hoping for some help in understanding the language. It works perfectly and prints out values to the serial monitor like “FFFFEEOFFF”. Assuming that is one of the values can you explain how to write a code so that when that value is read by the infrared sensor a servo motor starts. Thanks so much.
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
If it really printed a value like that, it is not working perfectly.
This statement
says to print the value of the value member in the class instance called results, in hex format. The value member is an unsigned long, which is 4 bytes. So, the value printed would be a maximum of 8 characters.
Yours has 10.
Your going to kick yourself…
unsigned long someValue = 0xXXXXXXXX; // where XXXXXXXX is the actual value
// printed by the code you showed
if(results.value == someValue)
   // Do something...
