Setting minutes on RTC DS1307 with button not working
Hello!
What I want to do: increase minutes displayed on my gLCD, with the push button (hours will be implemented after I make it work).
What I did: I set arduino in SLEEP_MODE_PWR_DOWN, with the "wake up" every 60 seconds, together with possible interrupt from button connected to INT4 on pin 7. Interrupt works correctly.
So I set a flag inside it, and put an if-statement in the loop() which (at least I think it should) checks the flag and accordingly increments the tm.Minute part of the tm structure.
What is wrong: Minutes are increased, BUT clock increments 8(!) minutes every 1 minute, and what is even more important the whole function responsible for correct time display somehow DOES allow minutes to exceed 60 :frowning: After overflow -> hours are NOT incremented
Jugding by that magic 8 value, I discovered that is the exact number of my loop() entering sleep mode (because I wanted to have longer sleep than 8 seconds).
However, I have no idea how to discern the difference for the program, something like:
"when entering watchdog interrupt do not change the flag, instead make an additional interrupt ONLY for button press, where the flag should be changed".
Then I guess everything should be fine.
Does anybody know how to write such a interrupt routine only for button, without changing the sleep&wake operation?
Or maybe there is an easier way to do that?
Code:
#include "U8glib.h"
#include <Wire.h>
#include <DS1307RTC.h>
#include <Time.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
tmElements_t tm;
volatile boolean flag;
const int indicatorLed = 13;
U8GLIB_DOGM128 u8g(11, 10, U8G_PIN_NONE); //U8GLIB_DOGM128(cs, a0 [, reset])
    digitalWrite (7, HIGH);
    // We start the I2C on the Arduino for communication with the RTC.
    Wire.begin();
    pinMode(indicatorLed, OUTPUT);
    digitalWrite(indicatorLed, LOW);
    u8g.firstPage();
    do {
      draw();
    } while( u8g.nextPage() );
    myWatchdogEnable (0b100001);
    myWatchdogEnable (0b100001);//48s
    myWatchdogEnable (0b100000);//+4s
    myWatchdogEnable (0b000110);//+1s
    myWatchdogEnable (0b000101);//+0.5s
    myWatchdogEnable (0b000011);//+0.125s
    myWatchdogEnable (0b000010);//+0.0625s
void draw(void) {
    // graphic commands for drawing including drawgraph()
    u8g.setFont(u8g_font_6x12);
    //tmElements_t tm;
    //RTC.read(tm);
    myTime(flag);
    u8g.setPrintPos(10, 128);
    print2digits(tm.Hour);
    u8g.write(':');
    print2digits(tm.Minute);
    u8g.write(':');
    print2digits(tm.Second);
//credit to Nick Gammon
void myWatchdogEnable(const byte interval) {
  MCUSR = 0;                          // reset various flags
  WDTCSR |= 0b00011000;               // see docs, set WDCE, WDE
  WDTCSR =  0b01000000 | interval;    // set WDIE, and appropriate delay
  wdt_reset();
  set_sleep_mode (SLEEP_MODE_PWR_DOWN);
  attachInterrupt (4, wake, LOW);   // allow grounding pin 2 to wake us
  sleep_mode();   // now goes to Sleep and waits for the interrupt
  detachInterrupt (4);
void print2digits(int number) {
  if (number >= 0 && number < 10) {
    u8g.write('0');
  u8g.print(number);
void drawgraph(void){
  //draws a chart
ISR(WDT_vect) {
  wake();  // disable watchdog
// interrupt service routine for when button pressed
void wake ()
  flag = true;
  wdt_disable();  // disable watchdog
}  // end of wake
void addMin(tmElements_t &tm){
  tm.Minute++;
void myTime(bool flag){
  if (flag){
      RTC.read(tm);
      addMin(tm);
      RTC.write(tm);
      flag = false;
EDIT: I wanted to add
ISR(INT6_vect){
  flag = true;
  wdt_disable();
but unfortunately it doesn't compile with the error:
Arduino: 1.0.6 (Windows 7), Board: "Arduino Leonardo"
core.a(WInterrupts.c.o): In function __vector_7': D:\ARDUINO\hardware\arduino\cores\arduino/WInterrupts.c:260: multiple definition of __vector_7'
wszystko.cpp.o:D:\ARDUINO/wszystko.ino:193: first defined here
  tm.Minute++;
You seem to be doing nothing to act on the overflow. Is it supposed to happen automatically ? If so can you provide a link to substantiate that ?
UKHeliBob:
tm.Minute++;
I think the proof is in Time library:
Link to library
breakTime() function
Before doing my minute increments everything was fine!
