Setting parity check in SoftwareSerial
Hello,
I'm trying to communicate with a module which is defined these items for its serial interface:
  • 1 start bit
  • 8 data bits
  • 1 stop bit
  • Odd parity check
  • No Flow control
I think everything is fine but Odd parity check. I was not able to set the odd parity check to software serial instance. Any idea for communicating with such a device? (like another library or ...?!)
Thanks
AFAIK SWSerial cannot set parity (you could MOD the source)
Maybe this one does? - AltSoftSerial Library, for an extra serial port ?
(did not investigate)
Hi Epsilon, I have the same problem as you.
Thanks to robtillaart advise, I made some research on AltSoftSerial library but it seems that you can't set parity. :frowning:
Maybe you could modify it by yourself following that :
In any case, I will continue my investigation in order to find an appropriate library. :wink:
You could try this:
