In recent weeks I try to run two RFID RC522 on the same arduino using the SPI interface. I checked that each of my connections worked separately. Then I plugged in both at the same time and neither of them work. I checked that each PIN was plugged in correctly and checked that SS and RESET were different for each RC522.
I use an arduino of this type: ATmega328P CH340G 5 V Micro
I did some actions:
Check that my library for the RFID reader used an SPI library with transactions.
Test a basic implementation without a standard library
None of these tests was conclusive, I went through many documentations and thread of discussions without overcoming my worries.
You need to post your program and tell us exactly what it does and what you want it to do that is different.
I wonder if your code needs to set the SS pin "off" for one device before trying to talk to the other device? The library will not know that there are two devices.
constexpr uint8_t RST_PIN = 9; // Configurable, see typical pin layout above
constexpr uint8_t SS_1_PIN = 10; // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 2
constexpr uint8_t SS_2_PIN = 8; // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
constexpr uint8_t NR_OF_READERS = 2;
byte ssPins[] = {SS_1_PIN, SS_2_PIN};
SETUP :
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
// Look for new cards
if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
Serial.print(F("Reader "));
Serial.print(reader);
// Show some details of the PICC (that is: the tag/card)
Serial.print(F(": Card UID:"));
dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = mfrc522[reader].PICC_GetType(mfrc522[reader].uid.sak);
Serial.println(mfrc522[reader].PICC_GetTypeName(piccType));
// Halt PICC
mfrc522[reader].PICC_HaltA();
// Stop encryption on PCD
mfrc522[reader].PCD_StopCrypto1();
} //if (mfrc522[reader].PICC_IsNewC
} //for(uint8_t reader
// RFID lib change SS PIN to LOW or HIGH
Writes a byte to the specified register in the MFRC522 chip.
The interface is described in the datasheet section 8.1.2.
void MFRC522::PCD_WriteRegister( PCD_Register reg, ///< The register to write to. One of the PCD_Register enums.
byte value ///< The value to write.
SPI.beginTransaction(SPISettings(MFRC522_SPICLOCK, MSBFIRST, SPI_MODE0)); // Set the settings to work with SPI bus
digitalWrite(_chipSelectPin, LOW); // Select slave
SPI.transfer(reg); // MSB == 0 is for writing. LSB is not used in address. Datasheet section 8.1.2.3.
SPI.transfer(value);
digitalWrite(_chipSelectPin, HIGH); // Release slave again
SPI.endTransaction(); // Stop using the SPI bus
} // End PCD_WriteRegister()
Okay, my apologies for this post a bit messy. I will try to do things properly in this answer.
#include <SPI.h>
#include <MFRC522.h>
constexpr uint8_t RST_1_PIN = 9; // Configurable, see typical pin layout above
constexpr uint8_t RST_2_PIN = 7; // Configurable, see typical pin layout above
byte rstPins[] = {RST_1_PIN, RST_2_PIN};
MFRC522 mfrc522[NR_OF_READERS]; // Create MFRC522 instance.
* Initialize.
SPI.begin(); // Init SPI bus
mfrc522[reader].PCD_Init(ssPins[reader], rstPins[reader]); // Init each MFRC522 card
Serial.print(F(": "));
mfrc522[reader].PCD_DumpVersionToSerial();
* Main loop.
// Halt PICC
* Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
Here is the message displayed by the console after downloading on the arduino :
Reader 0: Firmware Version: 0x0 = (unknown)
WARNING: Communication failure, is the MFRC522 properly connected?
Reader 1: Firmware Version: 0x0 = (unknown)
No reaction for each reader if I use an RFID token.
If I remove one of the MISO (lecteur 1 or 2), it works.
The MFRC522 is a 3.3V chip. As you say that your setup runs with only one reader the breakout board must contain some level converter. It seems that your board vendor doesn't use an SPI compatbile level converter (CS HIGH => MISO tri-state). Ask your vendor for schematics for your board. You might have to change the level converter to one that isolates MISO from the bus if CS isn't pulled down.
