Setting two pins to fast PWM
I'm building a wavetable VCO - and I found this code to set pin 3 to fast PWM (for the audio output):
#define PWM_PIN       3
#define PWM_VALUE_DESTINATION     OCR2B
#define PWM_INTERRUPT TIMER2_OVF_vect
TCCR2A = _BV(COM2B1) | _BV(WGM20);
TCCR2B = _BV(CS20);
TIMSK2 = _BV(TOIE2);
and then the interrupt timer does this..
PWM_VALUE_DESTINATION = outputvalue;
outputvalue = (((uint8_t)(osc.amplitude>>8)) * pgm_read_byte(sintable+((osc.phase>>16)%LUTsize)))>>8;
Alas though, I don't really understand this! And what I want to do is get a second PWM pin to do exactly the same (to create a second oscillator) - I read that pin 11 can also be set to fast PWM..
Does anyone know the code to implement this?
Carl
in the end, I just put analogWrite(11, outputvalue) - it works, but it's really clumsy and a little too slow.. Surely some of you clever people out there know how to address pin 11 by it's memory address?
Define:
#define PWM_PIN2       11
#define PWM_VALUE_DESTINATION2     OCR2A
and
PWM_VALUE_DESTINATION2 = outputvalue;
I just tried this but it's not working.. Still no sound on pin 11,,
Add this
TCCR2A = _BV(COM2B1) | _BV(WGM20) | _BV(COM2A1);
And don't forget to set 11 as output - pinMode.
