Hey guy I am new to the forum so go easy on me, and a newbie to Arduino yun. Okay here is my problem… I am having trouble setting up the connect between php and mysql connection. First, Install this package
opkg update
opkg install libpthread libncurses libreadline mysql-server
sed -i 's,^datadir.*,datadir = "/srv/mysql",g' /etc/my.cnf
sed -i 's,^tmpdir.*,tmpdir = "/tmp",g' /etc/my.cnf
mkdir -p /srv/mysql
mysql_install_db --force
/etc/init.d/mysqld start
/etc/init.d/mysqld enable
mysqladmin -u root password 'new-password'
opkg update
opkg install php5-mod-mysql
sed -i 's,;extension=mysql.so,extension=mysql.so,g' /etc/php.ini
I followed these instructions from
http://wiki.openwrt.org/doc/howto/lamp
Then I edited my php.ini file to run mysql in php
nano /etc/php.ini
here are the change I made to php.ini
[MySQL]
mysql.allow_local_infile = On
mysql.allow_persistent = On
mysql.cache_size = 2000
mysql.max_persistent = -1
mysql.max_links = -1
mysql.default_port = 3306
mysql.default_socket = /tmp/run/mysqld.sock
mysql.default_host = 192.168.x.x
mysql.default_user = root
mysql.default_password = new-password
mysql.connect_timeout = 60
mysql.trace_mode = Off
After that I use mysqladmin -u root -p create arduino
to create a database
Finally I use mysql -u root -p
to create a table and populate the table using mysql commands
here is my php code
<?php
// sql command is mysql -u root -p
$DBServer = '192.168.x.x';
$DBUser = 'root';
$DBPass = 'new-password';
$DBName = 'arduino';
$conn = mysql_connect($DBServer, $DBUser, $DBPass); not connecting
if (isset($_GET)){
$DoorBell_State =$_GET["value"];
echo $DoorBell_State;
// echo "Date and Time";
In the end when I try to connect to the database I get
Warning: mysql_connect(): Lost connection to MySQL server at 'reading initial communication packet', system error: 146 in /mnt/sda1/Front/index.php on line 15
Can SomeOne please help me connect to my … mysql database on my board. I want to Insert a GET evens into my sql database on the board…
any help would be deeply appreciated
Thanks
Sean
P.S a pointer to a good and clear tutorial would be helpful
