Setting up dependancies in properties for library.
When one submits a library for the IDE you can add a "dependancies=xxx" line to it for showing what library that yours would be dependent on. What if there are multiple libraries to list?
Is this the proper way? Just to list them?
depends=LC_baseTools Adafruit_NeoPixel
Or would I need to add multiple lines?
depends=Adafruit_NeoPixel
I used the first version (a guess) and it went through. But I really have no way, that I know of, to check if it worked or not.
-jim lee
jimLee:
Make sure that you spell the property right: "depends"
jimLee:
From the Arduino Library Specification:
https://arduino.github.io/arduino-cli/latest/library-specification/#libraryproperties-file-format
a comma-separated list of dependencies
jimLee:
This is specifying a dependency on a single library named "LC_baseTools Adafruit_NeoPixel".
Note also that the library name is "Adafruit NeoPixel", not "Adafruit**_**NeoPixel":
The dependencies system will only work if you specify the exact name of the library that is in the Library Manager index.
jimLee:
The second definition of the depends property overrides the first one, so this is equivalent to depends=Adafruit_NeoPixel.
jimLee:
The validation of the library on submission to the Library Manager index is currently not very strict.
jimLee:
Well, now that it's in Library Manager, you can surely try installing it, which will give you some indication that there is a problem:
no protocol:
java.lang.RuntimeException: java.net.MalformedURLException: no protocol:
 at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onInstallPressed$4(LibraryManagerUI.java:248)
 at java.lang.Thread.run(Thread.java:748)
Caused by: java.net.MalformedURLException: no protocol:
 at java.net.URL.<init>(URL.java:593)
 at java.net.URL.<init>(URL.java:490)
 at java.net.URL.<init>(URL.java:439)
 at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:64)
 at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:60)
 at cc.arduino.contributions.libraries.LibraryInstaller.performInstall(LibraryInstaller.java:155)
 at cc.arduino.contributions.libraries.LibraryInstaller.install(LibraryInstaller.java:125)
 at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onInstallPressed$4(LibraryManagerUI.java:237)
 ... 1 more
If you want to do a more thorough check of the metadata and structure of your library, I recommend Arduino Lint:
https://arduino.github.io/arduino-lint/latest/
$ arduino-lint --library-manager update
Linting library in E:\electronics\git-nobackup\LC_neoPixel
Rule LS008 result: fail
WARNING: No header file found matching library name (LC_neoPixel.h). Best practices are for primary header filename to match library name.
Rule LP021 result: fail
WARNING: library.properties version value 1.0 is not compliant with the semver specification. See https://semver.org/
Rule LP035 result: fail
WARNING: A commonly misspelled word was found in the library.properties paragraph field. Suggested correction: This library allows setting and retereving NeoPixel colors using our colorObj class. Shifting a strings of pixels left or right and to rolling rings of pixels clockwise or counter clockwise. (Great for goggles.) The included chainPixel class allows groups of pixels to be coded independently from each other, while running off of a single processor pin. (Again, imagine goggle rings)
Rule LP038 result: fail
ERROR: Invalid category field value Uncategorized in library.properties. See https://arduino.github.io/arduino-cli/latest/library-specification/#libraryproperties-file-format
Rule LP039 result: fail
WARNING: Use of "Uncategorized" category value in library.properties. Please use one of the allowed categories: https://arduino.github.io/arduino-cli/latest/library-specification/#libraryproperties-file-format
Rule LP048 result: fail
WARNING: library.properties depends field item(s) LC_baseTools Adafruit_NeoPixel not found in the Library Manager index.
Finished linting project. Results:
Warning count: 5
Error count: 1
Rules passed: false
Linting sketch in E:\electronics\git-nobackup\LC_neoPixel\examples\christmas_lites
Warning count: 0
Error count: 0
Rules passed: true
Linting sketch in E:\electronics\git-nobackup\LC_neoPixel\examples\goggle_lights
Warning count: 0
Error count: 0
Rules passed: true
Linting sketch in E:\electronics\git-nobackup\LC_neoPixel\examples\wreath_lites
Warning count: 0
Error count: 0
Rules passed: true
Finished linting projects. Results:
Warning count: 5
Error count: 1
Rules passed: false
There is also a GitHub Actions action that makes it super easy to run Arduino Lint on every change and pull request in the GitHub repositories of your Arduino libraries to make sure no new problems are ever introduced:
Thanks! That's what I needed to know.
-jim lee
You're welcome.
