I resently got the arduino ethernet sheild and can't seem to connect the damb thing no matter how many threads I read. It isn't one of the newer boards so there is no sticker w a mac address, but from what I read, it doesn't matter. I'm trying to run the web client example on my Mac, but keep getting the error message: "Failed to configure Ethernet using DHCP."
I found this thread helpfull, but it still doesn't work. http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1238029322. Following kg4wsv advice, I enabled internet sharing and looked up the IP address from the command prompt. I changed the last digit of the IP address (tried several combinations) and still nothing. Any help would be greatly appreciated.
You give little in technical details. What type of ethernet shield do you have (there at least two very different types)? To what and how is your arduino connected to something?
I’m running the arduino uno btw and connecting to my ethernet with a standard rj45 ethernet cable. I know the cable works bc I use it at school. So I don’t think it’s that. Here is the code I’m running, all I changed was the mac address and IP address.
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFF, 0xEF };
IPAddress server(192,168,2,2); // Google
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// start the serial library:
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.0");
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for(;;)
Client test code to see if your hardware is set up correctly.
//zoomkat 12-08-11
//simple client test
//for use with IDE 1.0
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan assigned to arduino
//byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
//byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
byte myserver[] = { 208, 104, 2, 86 }; // zoomkat web page server IP address
void setup(){
Ethernet.begin(mac, ip);
//Ethernet.begin(mac, ip, subnet, gateway);
Serial.println("Better client test 12/01/11"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(myserver, 80)) { //starts client connection, checks for connection
client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
Serial.print(c); //prints byte to serial monitor
Serial.println("==================");
client.stop(); //stop client
Thanks zoomkat!! The program worked, this is what I got:
connected
HTTP/1.1 200 OK
Date: Wed, 15 Feb 2012 23:16:44 GMT
Server: Apache
Last-Modified: Sat, 13 Nov 2010 16:31:40 GMT
Accept-Ranges: bytes
Content-Length: 51
Connection: close
Content-Type: text/plain; charset=UTF-8
Woohoo! Your arduino ethernet client works!
zoomkat
disconnecting.
I played around with it a bit and if I change the IP address it fails. Is the IP address assigned to the arduino (ie it could be anything on the same network) or is that the IP address to the site with the text file I recieved?
Below is code that connects to www.google.com somewhat like the sample program without using an IP address. Be aware that the google search used in the example for arduino will send back a lot of stuff.
//zoomkat 2-13-12
//DNS and DHCP-based web client test code
//and to see test result
//browser equivelant URL:
//http://web.comporium.net/~shb/arduino.txt
#include <SPI.h>
char serverName[] = "www.google.com"; // zoomkat's test web page server
void setup(){
Serial.println("DNS and DHCP-based web client test 2/13/12"); // so I can keep track of what is loaded
while(true);
// print your local IP address:
Serial.print("Arduino IP address: ");
for (byte thisByte = 0; thisByte < 4; thisByte++) {
// print the value of each byte of the IP address:
Serial.print(Ethernet.localIP()[thisByte], DEC);
Serial.print(".");
void loop(){
if (client.connect(serverName, 80)) { //starts client connection, checks for connection
client.println("GET /search?q=arduino HTTP/1.0"); //download text
else {
