I would like to use a more powerful IDE for my Arduino projects, and also for just learning C/C++ in general. I installed latest version of Eclipse (Luna), and Java (all 64 bit). I have found several sets of instructions for how to set up for coding/compiling/uploading for Arduino (Uno R3 in my case). i am not a coder, though I have mucked around in Visual Studio a bit so know a teensie bit about sw dev. I installed the Eclipse AVR plugin. My basic approach was to use the exisitng ArduinoCore.a library from the the Arduino install directory, rather than compiling myself. I put it in a folder, and pointed Eclipse to it in the compiler and linker setups. I almost got it working but am getting a "cannot find -lcore" from the linker. not sure why?
make all
Building target: test3.elf
Invoking: AVR C++ Linker
avr-gcc -Wl,-Map,test3.map,--cref -mrelax -Wl,--gc-sections -L"C:\Users\twelti\workspace\ArduinoCoreLibrary" -mmcu=atmega328p -o "test3.elf" ./src/test3.o -lArduinoCore -lm -lc -lprintf_flt -lcore
c:/winavr-20100110/bin/../lib/gcc/avr/4.3.3/../../../../avr/bin/ld.exe: cannot find -lcore
make: *** [test3.elf] Error 1
18:09:43 Build Finished (took 288ms)
I have read somewhere that I would need a "debug" version of the core library if I want to debug in Eclipse. If so, I guess I will need to bite the bullet and compile ArduinoCore (using both build and debug configurations). I guess I'm just wanting to know which is the best reference (i.e. most current and correct and complete) for doing all this.
Another question is, should I use the Arduino Eclipse IDE named Sloeber - Welcome! plugin? As I understand, it makes the Eclipse IDE look more like Arduino IDE, and does some (all?) of the code mangling that Arduino IDE does. i also found instructions (like at the bottom of: Arduino Playground - Eclipse ), for how to just put in the proper code to do that. Is there any other advantage of using the baeyens plugin?
Also, and current suggestions on a serial monitor? can I just use the one in Arduino IDE? I'm getting a headache...
