Setting up Nano Every as SPI slave
Hi!
I am trying to configure my Nano Every as a SPI slave.
Unfortunately, this is not really straighforward, and some registers have to be set (same as with Uno and Mega basically..)
Here is the code I used. Also, I had Unfortunately, it isnt working and I am not getting any interrupts when sending from my master microcontroller. I already tested the communication with an Uno and a Mega.
#include <Arduino.h>
//#include <SPI.h>
#include <avr/interrupt.h>
/* Globals */
bool spiMessageToBePrinted = false;
uint8_t buf [100];
volatile byte pos = 1;
volatile boolean process_it = false;
volatile byte interruptCounter = 0;
volatile byte messageSize = 0;
bool isStringMessage = true;
  Serial.begin(115200); // opens and configures the USB serial port for baudrate 115200
  Serial.println("Arduino: SPI Communication setup");
  // have to send on master in, *slave out*
  //PORTE.DIR &= ~PIN0_bm;  /* Set MOSI pin direction to input */
  //PORTE.DIR |= PIN1_bm;   /* Set MISO pin direction to output */
  //PORTE.DIR &= ~PIN2_bm;  /* Set SCK pin direction to input */
  //PORTB.DIR &= ~PIN1_bm;  /* Set SS pin direction to input */
  // turn on SPI in slave mode
  SPI0.CTRLA = SPI_DORD_bm          /* LSB is transmitted first */
               | SPI_ENABLE_bm      /* Enable module */
              & (~SPI_MASTER_bm);  /* SPI module in Slave mode */
  SPI0.INTCTRL = SPI_IE_bm;        /* SPI Interrupt enable */
  Serial.println("SPI registers on ATmega4809 were set: ");
  Serial.print("SPI0_CTRLA: ");
  Serial.println(SPI0_CTRLA, DEC);
  Serial.print("SPI0_CTRLB: ");
  Serial.println(SPI0_CTRLB, DEC);
  Serial.print("SPI0_INTCRTL: ");
  Serial.println(SPI0_INTCTRL, DEC);
  Serial.print("SPI0_INTFLAGS: ");
  Serial.println(SPI0_INTFLAGS, DEC);
  Serial.print("SPI0_DATA: ");
  Serial.println(SPI0_DATA, DEC);
  sei();
  //Serial.println(MISO);
  //Serial.println(SS);
  //Serial.println(MOSI);
  //Serial.println(SCK);
  pinMode(MISO, OUTPUT);
  pinMode(MOSI, INPUT);
  pinMode(SCK, INPUT);
  pinMode(SS, INPUT);
  // turn on interrupts
  if (process_it) {
    if(isStringMessage){
      Serial.print((char *)buf);
    else {
      Serial.println("SPI: packet received");
      buf [pos] = 0;
      Serial.println("SPI: Received data:");
      for(int i=0; i < messageSize ; i++) {
        Serial.println(buf[i],DEC);
    process_it = false;
    pos = 0;
  }  // end of flag set
// SPI interrupt routine
ISR(SPI0_INT_vect) {
   byte c = SPI0_DATA;
  // Echo Reply
  SPI0_DATA = c;
  //Serial.println((char)c);
  //interruptCounter ++;
  // add to buffer if room
  if (pos < sizeof(buf)) {
     buf [pos++] = c;
     if ((char)buf[pos-1] == '\n' and (char)buf[pos-2] == '\r' and process_it == false) {
       process_it = true;
       buf[pos] = '\0';
       messageSize = pos;
       pos = 0;
  SPI0.INTFLAGS = SPI_IF_bm; /* Clear the Interrupt flag by writing 1 */
}  // end of room available
It would be great if someone could try out that code. Maybe you can see a mistake.
I will test this with an Arduino Master later. Also I am wondering why the SPI slave configuration has not been properly added to the SPI library yet. Thanks a lot in advance for any help!
Cheers
