In the Code below I used Serial.println() to debug the Program.
It do not execute any of the Serial.println().
I could upload the Code without Problems.
What could be cause ?
Thanks
#include <GSM.h>
#define PINNUMBER
#define PIR 2
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
GSMVoiceCall vcs;
char numtel[20];
pinMode(PIR, INPUT);
while(!Serial);
// connection state
bool notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while (notConnected) {
if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
notConnected = false;
vcs.hangCall();
Serial.println("setup-okay");
Serial.println("loop-okay");
if(digitalRead(PIR) == HIGH) {
Serial.println("PIR okay");
char remoteNum[20] = {""}; // telephone number to send sms
// sms text
char txtMsg[200] = {"Hi, someone seems into your Object !?"};
// send the message
sms.beginSMS(remoteNum);
sms.print(txtMsg);
sms.endSMS();
switch (vcs.getvoiceCallStatus()) {
case IDLE_CALL: // Nothing is happening
case RECEIVINGCALL: // Yes! Someone is calling us
// Retrieve the calling number
vcs.retrieveCallingNumber(numtel, 20);
// Answer the call, establish the call
vcs.answerCall();
case TALKING: // In this case the call would be established
Use a Serial.println(…) into the setup function before the first while. Then you now, that your program runs.
Your while loop should have a time Limit, actual IT can hang endless…
//while(!Serial); // not running
// connection state
// Start GSM shield
Serial.println("connected");
Serial.println("Not connected");
vcs.hangCall();
Serial.println("Waiting for a call!");
Which loop do you mean, the while(!Serial); I commented out, now it's just the Connection state loop ?
I tested the SIM-card on a normal Mobile-phone and it's activated and works.
"Edit-1" Not sure about this, perhaps it's because the Power, or the SIM-card type (I use 4G-SIM, and Power from the USB ?) :
As written in the Specification for GSM-Shield-2 :
Power It is recommended that the board be powered with an external power supply that can provide between 700mA and 1000mA. Powering an Arduino and the GSM shield 2 from a USB connection is not recommended, as USB cannot provide the required current for when the modem is in heavy use.
and
SIM to use with this shield The GSM shield 2 is compatible with Data only and Voice and Data SIM. GPRS and SMS are supported by 2G Data only SIM, while voice calls, supported by the hardware, require a Voice and Data SIM, the same you may use in a GSM mobile phone. The Data transfer is based on GPRS technology and therefore it is not compatible with 3G or UMTS only network providers. GPRS is a 2G technology.
The Code works, but the Hardware does not work at all, as excepted.
It sends SMS, and receive calls, just the Audio don’t work.
As Example, the Microphone connected to the Audiojack of the GSM-Shield V2, do not work.
I will try to use the soldering points (M1P/M1N) on the shield, for the Microphone.
And the digital-PIN 8 on the Arduino, seems to not get low, when the PIR-out connector is low.
#include <GSM.h>
#define PINNUMBER ""
#define PIR 8
GSM gsmAccess;
GSM_SMS sms;
GSMVoiceCall vcs;
char numtel[20];
//Serial.println("setup-okay");
//while(!Serial);
// connection state
// Start GSM shield
//Serial.println("connected");
theGSM3ShieldV1ModemCore.println("AT+QAUDCH=1"); // trying to get Audio/Speaker/Microphone) through Audiojack
theGSM3ShieldV1ModemCore.println("AT+QMIC"); // ""
//Serial.println("Not connected");
vcs.hangCall();
//Serial.println("Waiting for a call!");
//Serial.println("loop-okay");
char remoteNum[20] = {"SomeNumber"}; // telephone number to send sms
// sms text
// send the message
sms.print(txtMsg);
sms.endSMS();
//delay(2000);
digitalWrite(PIR, LOW);
if(digitalRead(PIR) == LOW) {
Serial.println("PIR down");
vcs.answerCall();
