I've got a puzzling setup() problem.
It should be called once, and once only, yet I'm seeing output from the setup() function whenever I connect to the board with the Arduino Serial Monitor.
The code is below. When I deploy it to the board it works just fine. Yet if I disconnect the Monitor, wait a while, then re-connect the monitor, I get the "USB Test Harness" print from the setup() function being repeated on each re-connection.
There is definitely no redeployment at the time I re-connect the Monitor, the green LED on the board remains constantly lit, and there are no flashes of any other LED.
Any suggestions why this might be happening?
Ron.
#include "NewSoftSerial.h"
const int usbrx = 2;
const int usbtx = 3;
const int usbcts = 4;
const int usbrts = 5;
NewSoftSerial usb(2,3);
char cmd[128];
char *cmdPtr;
void ProcessCommand (char *);
// setup Program initialisation
// Initialise serial ports.
Serial.begin (9600);
usb.begin (9600);
//lcd.begin (9600);
// Show startup message after a pause to enable monitor connection.
delay (5000);
Serial.println ("USB Test Harness");
Serial.println ("----------------");
Serial.println ("");
//delay (10000);
// Initialise IO pins
pinMode (usbrx, INPUT);
pinMode (usbtx, OUTPUT);
pinMode(usbrts, INPUT);
pinMode(usbcts, OUTPUT);
//pinMode (lcdrx, INPUT);
//pinMode (lcdtx, OUTPUT);
// Initialise command buffer
cmdPtr = cmd;
memset (cmd,0,sizeof(cmd));
// Process Main processing loop. Get commands from
// the serial port and pass to processing.
void loop () {
// Process characters from serial port
while (Serial.available() ) {
*cmdPtr = Serial.read ();
// Expect commands to be terminated by CR
if (*cmdPtr == '\r') {
ProcessCommand (cmd);
cmdPtr = cmd;
else ++cmdPtr;
// ProcessCommand Process a command by sending it to the
// USB drive, then printing the response.
void ProcessCommand (char *cmd) {
char ch,lastch;
// Log the command to the monitor
Serial.print ("Processing command ");
Serial.println (cmd);
// Send the command to the USB key. Wait a few milliseconds to give the
// USB interface time to respond.
usb.print (cmd);
delay (10);
// Write any response to the monitor
while (usb.available()) {
// Don't allow the USB interface internal buffer to overflow.
if (usb.available() > 8) {
digitalWrite(usbcts, HIGH);
else {
digitalWrite(usbcts, LOW);
ch = usb.read ();
if (ch == 13 && lastch != 10) Serial.write (10);
Serial.write (ch);
lastch = ch;
// Notify end of command.
Serial.println ("Processing complete");
